Thread: New guy
Results 1 to 3 of 3
  1. #1 New guy
    SE Level Member lilwillgp's Avatar
    Indiana
    Hey, NOOB here. I'll admit it. anyways I have a 98 GT that I want to turbo. It seems to be the best bang for buck route. I plan to piece my set together...while doing fab work if I have to. I plan to keep my GP as a DD. it has about 165 on the clock, and a rebuilt tranny.
    What turbo should I use? I want something thats small enough to spool up fairly quickly, but still able to give gobs of power.
    I was planning to do a rear mounted turbo, unless you can convince me not to.
    also, I will need to rebuild my tranny or diff (?) to withstand up to 500 hp. Any DIY kits?
  2. #2 Re: New guy
    Donating Users Tengis's Avatar
    Houston
    Going turbo is expensive. If you are asking about rebuilding differentials then you probably dont realize that a more reliable transmission on a 400-500hp setup will cost you more then your turbo kit.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  3. #3 Re: New guy
    SE Level Member BlackGS's Avatar
    Central Jersey
    Go to tripleedgeperformance.com for info on the tranny. As mentioned, upgrading the transmission to hold 500hp is going to be a big cost.
    For the turbo, there are a lot of options. The T67 or PT-61 seem to be the choice of many, and zzp is offering a BW 56mm, which would probably be good.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
guy
