Thread: Oil Pump ???
Results 1 to 3 of 3
  1. #1 Oil Pump ???
    SE Level Member TurboGTP's Avatar
    Cali
    Ok so i tried to start my car the other day, I cranked over & then died out . Then i got a Code for the MAF so i changed it out & tried it again but same thing. Then i checked my oil level & i noticed it looked like water & it smelled like gas . Then i took off the oil feed line that go's to the Turbo & cracked it over.... Nothing of oil came out ??
    Is there a wrong way to install the ZZP Oil Pump Gears ? Or what can be the problem.
    Show Me The Boost
  2. #2 Re: Oil Pump ???
    Donating Users kfish's Avatar
    Ohio
    i dont think it can be put in wrong, you got the outside gear and the inside gear. did you pack them full of assembly lube?
  3. #3 Re: Oil Pump ???
    Cali
    Quote Originally Posted by kfish View Post
    No i didn't use assembly lube just motor oil.
    Show Me The Boost
  1. Bad oil pump??
    By 2kgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2010, 01:28 PM
  2. Air pump.
    By jtrain771 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2010, 03:34 AM
  3. Oil Pump
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2009, 05:43 PM
  4. oil pump??
    By a.caldwell11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 02:07 AM
