Thread: which fuel pump and how much whp
Results 1 to 6 of 6
  1. #1 which fuel pump and how much whp
    GT Level Member rodman's Avatar
    Apr 2008
    Just wondering wich fuel pump you guys are running and how much whp your getting?
  2. #2 Re: which fuel pump and how much whp
    Topeka, KS
    Stock.... Upgrading your fuel pump will not net you WHP...
  3. #3 Re: which fuel pump and how much whp
    GT Level Member ChrisGTT's Avatar
    Nov 2008
    NY
    Stock with rewire will get you 400whp more or less build depending.
    Speed is an addiction the faster you go the slower it becomes.
    01 GT | Matt's new TT cam | PT-67 | 18-22psi and a couple stock trannys.
  4. #4 Re: which fuel pump and how much whp
    Quote Originally Posted by ChrisGTT View Post
    this.
  5. #5 Re: which fuel pump and how much whp
    Apr 2008
    Thanks
  6. #6 Re: which fuel pump and how much whp
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    i did 430whp and 469wtq on stock pump and wiring, the pump saw its limit at 4900rpms, and thats where my peak numbers were. a rewire proably would have gave me enough fuel to make some more power at 5k-6k 450whp is my guess.
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  3. Is there a way to run the fuel pump
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 06:09 PM
  4. fuel pump or FPR? or both?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 03:43 PM
