Like I said before, the wastegate location on the Z3 is the same location on the cartuning kit, just open dumped on the Z3. The Z7 kit is the one that has the wastegate location next to the throttle body, on the crossover. The wastegate on the cartuning kit is not over the valve cover either. The woosh sound does not come from running a open dump wastegate either, it comes from a blow off valve. The wastegate is what opens when the desired boost level is reached and releases exhaust pressure, so the exhaust tone would just get louder if running open dump wastegate... I don't even care if i sound like a dick, that was too much to type to go back through and undickify it! lol
Well I think some of these things are things you would do with any of these turbo kits. The other thing I forgot to mention was the dp comes really close to the rear valve cover, enough that you might have to unbolt the dp near the turbo and move it a bit to loosen the rear valve cover bolt. There is not much space between the brake booster and the rear head for a 2.5" pipe to go.
I wouldn't worry about him too much, most of the kit is sound enough and known well to get other vendors to offer parts for the kit or ask other people for solutions or parts.
