Thread: curious if going past 14.7psi....
Results 1 to 7 of 7
  1. #1 curious if going past 14.7psi....
    i understand our stock map is a 2bar where its capped at 14.7psi? if i want to increase boost past that, is there anything i should do specifically? do you guys who boost past 14.7 generally upgrade to a 3bar map or something?
  2. #2 Re: curious if going past 14.7psi....
    so long as your fueling isnt whacky, i dont know why you couldnt just go past it without worrying. youre still running an m90 car, so making more than 14.7 pounds of boost is a lot.
  3. #3 Re: curious if going past 14.7psi....
    sorry i should change my sig....im running a z7 turbo kit-which is why im in the turbo section.
    z7 kit with a T66 turbo. currently im running at ~14psi at ~20-21* of timing with a 10.5AFR and blips of knock(less than 1*). i cannot recall my IPWs. the highest i've seen my maff i need to check my recent scans. im using a LQ4 maff
  4. #4 Re: curious if going past 14.7psi....
    holy rich AFR batman. when are you going to lean that thing out, guy?
  5. #5 Re: curious if going past 14.7psi....
    well gradually i suppose. just got back form a run and its now at 10.05afr lol. but now my ls1m scanner is pegged at 14.35psi as im kinda over the 2bar map running 18* of timing and less than 1* of knock. my IPWs is at ~18-19mS fwiw. LTFTs locked in at +/-0.0
  6. #6 Re: curious if going past 14.7psi....
    btw, i think my alky controller was spraying during those runs. i turned the "START" to spray the alky all the way to 12psi(farthest it'll go) as well as the "MAX PSI" at 15psi. since im boosting over 14psi i think its spraying causing the rich AFR. i need to disconnect the alky controller totally and see what my AFR is really.
  7. #7 Re: curious if going past 14.7psi....
    well, id say so long as youre not knocking then i wouldnt worry about it.
  1. Vehicles you have or have owned in the past
    By IndeedSS in forum Off Topic Discussion
    Last Post: 04-07-2015, 08:53 AM
  2. BELT SLIP, a thing of the past now people.
    By GR8racingfool in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2013, 07:41 PM
  3. im just curious
    By occrocks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2009, 08:09 PM
  4. Car not acellerating past 30mph
    By Bonvoi29 in forum General Tech Discussion
    Last Post: 05-22-2008, 01:38 PM
  5. Pics i took over past two weeks 56k/\_/\_______
    By aquase in forum Off Topic Discussion
    Last Post: 01-04-2008, 06:27 AM
