Thread: Wideband
Results 1 to 18 of 18
  1. #1 Wideband
    SE Level Member TurboGTP's Avatar
    Cali
    What is a good Wideband to get for my car ? I will be going turbo so i need to get one. Any info would be good Thanx
    Show Me The Boost
  2. #2 Re: Wideband
    i always liked the AEM setup because it came with a gauge.
  3. #3 Re: Wideband
    Cali
    Do you know which one or part number ?
    Show Me The Boost
  4. #4 Re: Wideband
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Wideband
    SE Level Member Spockssilver02's Avatar
    Aug 2008
    Kennesaw, GA
    I've been very happy with the NGK unit. It seems to get good reviews for accuracy. It comes with a Bosch O2 sensor, although you can upgrade to an NGK O2 sensor.
    Home » Shop » Wideband O2 » O2 Controller » NGK Powerdex AFX - Air Fuel Ratio Monitor Kit - Wideband O2 - PN 91101 - w/ Standard Sensor
    02 Silver GTP - 3.3 MPS, XP, 105s, Ported Gen 3 & LIM, Wizaired CAI, TOGs, N*, LQ4 MAF, PRJ Wires, 180 stat, AL 104s, GMPP handling kit, AGX, Eibach, HPT, NGK WB
  6. #6 Re: Wideband
    Cali
    Thanx for that info guys.. The Innovate Wideband looks pretty good, I might get that 1.
    Show Me The Boost
  7. #7 Re: Wideband
    Banned - Busted For Scamming
    Feb 2009
    You can get the aem for the same price buy it now on ebay.
  8. #8 Re: Wideband
    Cali
    Quote Originally Posted by TurboGTP View Post
    Which one do you guys think is better ?
    Please wait
    Image not available
    Show Me The Boost
  9. #9 Re: Wideband
    Charles City, IA
    I have the NGK AFX
    SMGPFC Two Nipple General
  10. #10 Re: Wideband
    they all work the same, get the one you like how it looks and know you can mount it somewhere you want it.
  11. #11 Re: Wideband
    Charles City, IA
    I pulled out my ash try and have mine down there.
  12. #12 Re: Wideband
    Cali
    I have the NGK AFX
    Are you happy with it ? Does it work good, any problems with it ?
    Show Me The Boost
  13. #13 Re: Wideband
    Charles City, IA
    Works fine. I have had no problems with it. I am recording from it threw my egr wiring.
  14. #14 Re: Wideband
    Cali
    Oh ok thanx for the info.
    Show Me The Boost
  15. #15 Re: Wideband
    Jan 1970
    Maquoketa, Iowa
    I have the PLX M-400 mounted in front of the speedo on the steering wheel. I like the AEM's also, we put one in a regal, easy install.
  16. #16 Re: Wideband
    SE Level Member BlackGS's Avatar
    Central Jersey
    What are you using to scan/tune? I have the PLX SM-AFR which integrates easily with HP Tuners.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  17. #17 Re: Wideband
    Cali
    Quote Originally Posted by BlackGS View Post
    I don't have no scaner & i'm not going to tune my car. Some guy is going to Tune it for me that Tunes GM Cars
    Show Me The Boost
  18. #18 Re: Wideband
    I have the NGK AFX
    x2. is what im using right now
  1. Wideband AFR where should....?
    By GTP4 in forum PCM Tuning
    Last Post: 04-21-2009, 11:57 AM
  2. Anyone run an LC1 Wideband...
    By Iron Indian in forum Off Topic Discussion
    Last Post: 03-24-2008, 09:41 PM
