Thread: Throttle plate spacer
Results 1 to 7 of 7
  1. #1 Throttle plate spacer
    GT Level Member rodman's Avatar
    Apr 2008
    R these thing's any good for turbo builds
  2. #2 Re: Throttle plate spacer
    I live here. UR LOSN's Avatar
    Rockford, IL
    if you have an Intercooler, you really dont have to worry about heat soak like the blowers......
    but every little bit helps.
  3. #3 Re: Throttle plate spacer
    TDCRacing
    Guest
    Most people run the 04+ intake on a turbo build. Because they are aluminum and don't crack like the cheap plastic ones. If you have a 97-03 and do this then you must run a conversion TB spacer. Because you can't run a drive by wire TB on a 97-03.
    Check out my new product.
    http://www.grandprixforums.net/f51/t...tml#post154657
  4. #4 Re: Throttle plate spacer
    Rockford, IL
    gee, that was a helpless plug if I ever saw one...
  5. #5 Re: Throttle plate spacer
    TDCRacing
    Guest
    Quote Originally Posted by UR LOSN View Post
    Yeah.....LOL
    You know I shipped you're blower right?
  6. #6 Re: Throttle plate spacer
    Rockford, IL
    I CANT WAIT! think I will slap it on along with the rockers this weekend... if it gets here by then.
  7. #7 Re: Throttle plate spacer
    TDCRacing
    Guest
    It should. I sent it the day I left you feedback.
  1. throttle body spacer
    By danross in forum General Tech Discussion
    Last Post: 02-19-2009, 06:40 PM
  2. Phenolic Throttle Body Spacer [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 09-27-2008, 03:21 PM
  3. throttle body spacer
    By NKYspdemon in forum Off Topic Discussion
    Last Post: 06-30-2008, 08:45 PM
  4. Phenolic Throttle Body Spacer
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2008, 01:12 PM
  5. Throttle Body Spacer
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2008, 06:21 PM
