Thread: what gaskets ?
Results 1 to 2 of 2
  1. #1 what gaskets ?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    Hi all ,
    I recently got my hands on a turbo GTP, with the cartuning turbo kit. it has an exhaust leak and i want to replace all of the gaskets. Specifically the rear manifold blockoff gasket, upper to lower DP gasket, and lower DP to catback. Im also open to replacing anything else you folks suggest .
    Im assuming that the rear exhaust manifold gasket is just the OEM gasket, even when using the ported rear mani. The ones im not sure about are upper to lower DP, and lower DP to catback. can i just use a normal 2.5 inch exhaust flange gasket?
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  2. #2 Re: what gaskets ?
    GT Level Member 94GrandPrixSE's Avatar
    Nebraska
    You will prob need to measure as the gaskets sizes can vary dp is optional 2.5 or 3. Should be able to get all ur measurements with it together still. As far as the manifold gaskets I haven’t had any problems with the oem steel style or the felpros.
  1. Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    By 01Blackgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2014, 06:36 PM
  2. Best LIM Gaskets to Use on 3.8 GT
    By indygrandprix in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2013, 05:57 PM
  3. lim gaskets
    By pontiaclemon in forum General Tech Discussion
    Last Post: 06-08-2012, 05:59 PM
  4. Bad gaskets?
    By RichardL12 in forum General Tech Discussion
    Last Post: 02-01-2011, 02:13 PM
  5. LIM Gaskets
    By RICE KILLER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 01:24 AM
