Thread: Cutting out under boost/heavy load.
Results 1 to 14 of 14
  1. #1 Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    Im turboed now btw.
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #2 Re: Cutting out under boost/heavy load.
    got a wideband in the car?
    did this just start happening? or has it been a issue since your build was finished?
  3. #3 Re: Cutting out under boost/heavy load.
    you deleted the whole first post there. so no one knows whats up any more lol
    turbo or not, same questions.
  4. #4 Re: Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    I just bought the LQ4 maf to put in because the MAF was running almost past 11500HZ. Possible spark gap issue im also wondering. Blowing the spark out?
  5. #5 Re: Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    Not sure what happened to original post but im turbo now. Started when I upped boost over 10psi.
  6. #6 Re: Cutting out under boost/heavy load.
    got a wide band in the car ill ask again? fuel pump upgrade? injector upgrade? if not theres the problem. the maf file the right one? hows the trims?
    see why you need a wb yet if you dont have one?
  7. #7 Re: Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    Have wide band, fuel pump upgraded and #60 injectors. Its in the 11.2 11.5 range when this is happening.
  8. #8 Re: Cutting out under boost/heavy load.
    Kemmerer, Wyoming
    what spark plugs are you running? might need a colder plug?
  9. #9 Re: Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    Im running the TR6 at factory gap
  10. #10 Re: Cutting out under boost/heavy load.
    Kemmerer, Wyoming
    I recommend trying a colder plug at a smaller gap like .045. factory gap is huge.
  11. #11 Re: Cutting out under boost/heavy load.
    try gaping them at 0.52
    when was your last tune up? id try some AL copper 103's or 104's. less then 15 bucks most of the time.
  12. #12 Re: Cutting out under boost/heavy load.
    Nov 2015
    Monroeville, Pa
    What?! .052 you mean
  13. #13 Re: Cutting out under boost/heavy load.
    220-221, what ever it takes lol
  14. #14 Re: Cutting out under boost/heavy load.
    Dec 2018
    Lehigh Valley, PA
    If you're maxing our your MAF it'll feel like an ignition problem, but it's not. I had the same problem with my Turbo T a few years back. I put an LS1 MAF and a translator (gotta love the old OBD1 ECMs) on it and no more cutting out over 10 psi. I eventually ran 18 psi in that car on the stock turbo. That was about all the stocker had in it. It was still pretty fast though.
  1. Heavy Isolated Misfire Under Load
    By Jomamma in forum General Tech Discussion
    Last Post: 11-15-2014, 02:20 AM
  2. Bucking/chugging under a heavy load (2002 GTP)
    By Green97GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2013, 08:28 AM
  3. N/A 3.8 cutting power under load?
    By Vinson clark in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2013, 02:52 PM
  4. cutting out under load and boost!!
    By Blowblackorgetback in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2012, 10:08 AM
  5. cutting out under a load
    By re209 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2011, 02:02 PM
