Thread: went back to the dyno and cant make over 15 psi?
Results 1 to 20 of 23
  1. #1 went back to the dyno and cant make over 15 psi?
    GT Level Member rodman's Avatar
    Apr 2008
    l32 bottom
    stage 1 zzp heads
    z7 turbo
    st3 cam
    7/8 triple edge trans
    60 lbp injectors
    700 hp fuel pump
    06 car that was na
    05 gtp pcm car did 330 whp at 14psi to 6500 rpm as soon as it gets turned up a to 15 or over dies about 5100 - 5200 rpm looked like 2 bar map was maxed out so tried 3 bar car ran terrible
    its like its hittin a governor ....is there something in the 05 gtp pcm that hp tuners cant see?looking to hit 400 whp what the next step?
  2. #2 Re: went back to the dyno and cant make over 15 psi?
    I don't think there is a way to adjust the linear/offset settings for a 3 bar sensor so it doesn't suprise me that is doesn't run great with one.
    Are you still running a MAF or aftermarket MAF?
  3. #3 Re: went back to the dyno and cant make over 15 psi?
    Apr 2008
    metal lt1 its not maxed out
  4. #4 Re: went back to the dyno and cant make over 15 psi?
    GXP Level Member
    Mar 2015
    Tomball
    There is a scaling factor in the MAP settings which is set to 200 with kPa/256 counts this comes out to 14.3 PSI gauge pressure this is the multiplier used to derive manifold pressure from the MAP by scaling the A/D input by the specified amount of kPa/ 256 counts.
    There is also a Sensor offset which is set stock to 7.99. It says this is the offset used in deriving manifold pressure from the MAP sensor.
    The Default max kPa is 160 as well.
    I really don't know as I am not there on boost yet to worry about it and for 04+ it seems getting the correct technical information is like pulling teeth. These settings are all stock 05' GTP settings.
    I know that I have seen as high as 174 kPa on my car which is right at 10.5 PSI gauge pressure. My car is stockish though.
    I don't know if you need to adjust the scaling factor or sensor offset or both. I have seen other 04+ tunes with these settings different, but don't know what the car had.
    Jeff
  5. #5 Re: went back to the dyno and cant make over 15 psi?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Put a stock map sensor in it and post a scan...
    What is your plug gap set at?
    What kind of wires and coils?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  6. #6 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    First off go back to the two bar map sensor the GM 3800 v6 PCM First off go back to the tube are map sensor the GM 3800 v6 PCM does not have the ability to run it effectively without a lot of horse trading in other areas.
    Second is to check and see if this 15 psi that you're seeing is via scanning software or through an actual mechanical boost gauge with a line running to the intake manifold.
    If you're going by the scanning software you will never see over 15 psi
    If however you're using a mechanical boost gauge and it is not going over 15 psi then you have an actual issue either with your wastegate blow off valve or a charge pipe coupler
    **** my phone
    ~James~ Psychotic Gearhead
  7. #7 Re: went back to the dyno and cant make over 15 psi?
    Kemmerer, Wyoming
    Quote Originally Posted by Turbocharged400sbc View Post
    **** my phone
    you fixed that quick, for a minute I was like, is he trying to kick a dead horse like 50 times.
  8. #8 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    I have no clue what happened but Google voice to text ****en hates me
  9. #9 Re: went back to the dyno and cant make over 15 psi?
    Kemmerer, Wyoming
    I would put the blame entirely on the google software, it's not like you could have said the same thing over and over exactly the same each time. I get a kick out of my father in law when he sends a text message. he has an iphone, and talks into it, and it is completely different than his normal speech.
    but to get back on topic, this probably won't help your problem a lot, but last year I took the supercharger off and put an N/A upper/lower intake on. I used the L32 map sensor because it is a 2 bar, and is the same physically as the L36/26 map sensors. at one point, I mistakenly put a na map sensor in, and the car ran bad for the one minute I let it run.
  10. #10 Re: went back to the dyno and cant make over 15 psi?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    sounds to me like it will make the boost, just falls on its face at 5100...spark blowout, torque management, icm issue...those are my guesses.
  11. #11 Re: went back to the dyno and cant make over 15 psi?
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    I'd say you have several issues. I make almost 450 to the wheels on 15 lbs, stock heads, st1 cam and 62mm turbo. 9 lbs is like 380 or something. Map doesn't matter, these pcms run on maf. I run 26lbs on a stock 2bar map.
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  12. #12 Re: went back to the dyno and cant make over 15 psi?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by SlowFiero View Post
    he has a lot less turbo they you do though. it does seem a bit low though...hrm...
  13. #13 Re: went back to the dyno and cant make over 15 psi?
    Feb 2008
    Canada
    Z7 kit comes with a 6262 turbo, same as mine, unless he has a old kit before the 6262 was included.
  14. #14 Re: went back to the dyno and cant make over 15 psi?
    Apr 2008
    its the older one t3/t04b I think
  15. #15 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    ok so I haven't seen that you confirmed that this boost reading is from a mech gauge or the oem MAP/scanning
    on the 04+ there are maf/map rationality tests (ie it should se max xxx at this psi, if false trigger limp/tq management
    lots of nanny features/on board diagnostics (technically its pretty damn near OBD3)
  16. #16 Re: went back to the dyno and cant make over 15 psi?
    Bastard Reptile's Avatar
    Kansas City, MO
    What's your MAF fail frequency at?
  17. #17 Re: went back to the dyno and cant make over 15 psi?
    Apr 2008
    I sent turbo Tim some scans from the Dyno .... He said my maf was ****ty spiking so I ordered a new one and this time I'm keeping the screen in ....
  18. #18 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    so can you tell us whether it was the scanner or a mechanical gauge that told you that you were not going over 15 psi
  19. #19 Re: went back to the dyno and cant make over 15 psi?
    Apr 2008
    Mechanical
  20. #20 Re: went back to the dyno and cant make over 15 psi?
    hangover park IL
    only things I can figure are mechanical issues that prevent the Turbo from producing.
    a restriction Downstream of the turbine would be an issue....
    it sounds though like mostly you're dealing with the fact that HP tuners sucks ass with the new cars and since you don't have access to Tiny tuner you can't fix the rationality tables that are f****** you right now
  1. Dyno Day $30 dyno pulls *now with FAIL* p3
    By danomite02 in forum Shows and Events
    Last Post: 10-01-2013, 04:44 PM
  2. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  3. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  4. If if dont make money it dont make cents
    By CrAnK_DaT_SoUjA_BoI in forum Introductions/Noob Questions
    Last Post: 08-18-2009, 01:00 AM
