Re: Just got a turbo kit, couple quick questions
GTPChristopher
I like Scotty's idea better. Why not save a few bucks when possible?
Me too, but don't we still need an adapter plate for the N* TB? Or does the north star bolt up to the L26 UIM?
GTPChristopher
Just out of curiosity, how much boost are you planning on running? The tranny is the weak link when going turbo and running high boost.
Once I get everything running, I'll probably have triple edge build up my trans.
SgtMarshal
some people have had bad luck with the LQ4 maf sensor and turbocharged applications. you could use an LT1 style maf, but it's old technology. the LS7 maf is a card style and would work better. another option is the mini afc, that zzp sells.
What's the difference in mafs between the lt1 and ls7? I'm assuming I'm going to need the housing from whichever one I get.
Scottydoggs
Yikes. Ok, will not go that route then.
BrandonHall10 built my tranny. He does phenomenal work, maybe shoot him a msg when you're ready and he could shoot you a quote.
Sent from my LGLS675 using Tapatalk
honestly no reason to run an aftermarket maf. get a fixed afc from zzp and be done with it. thats what im currently running...24psi. no issues.
I like how I got dragged into this lol
selliott
any time pal. :cool:
My thread is full of what not to do things
selliott
why its a great tool to have here lol
you do have the how to kill a tranny job all wrapped up. :th_thumb-up:
NebTurboST5
exactly, stock maf with some sort of afc is all you need.
GTPChristopher
x2
I went with a ported l67 tb, l26 upper and lower, and stock maf with an afc. Any maf you go with will require a retune. If you go lt or ls you can get a maf block off plate for the stock tb.
Air is being pushed in the by the turbo as apposed to sucked in by the supercharger so you don't need a big throttle body unless you have a really big turbo.
Oh Ya it never ends...;)
That's been my understanding, no big TB needed. Boost is boost and does the trick.
Ported L67 TB is what I'm using too.
Stock l67 TB for me and LT1 MAF, LT1 MAF is cheaper than an AFC if we want to get back to the saving a few dollars factor and is all I've ever needed and like said above anything other than stock needs tuning anyway. Oh yeah my car has been turboed and on this setup since 2005...not many can claim that.
I'm loving the turbo input right now, just saying 😀
I wanted a HPT tuner, however I ended up finding a used DHP that I got a really good deal on, so I guess I'll be using that. I figure if I don't like it, it shouldn't lose value. Should be here Friday. If I have a tuner, do I still need a scangauge? Thinking about going with this Wideband:
https://www.amazon.com/gp/product/B0...A1OSQ3YK654B89
I read that DHP scanning software is awful and to use UV scan instead, so I plan to do that. Will I be able to log this at the same time?
dhp scans just fine. its how long it takes to save thats a issue for some. uv scan is separate program that uses the dhp interface to log with.
that wb will work.
