Thread: Intercooler piping pictures
Results 1 to 20 of 29
  1. #1 Intercooler piping pictures
    GTP Level Member
    Jan 2015
    Lincoln, NE
    some people in my newbie thread wanted to see some intercooler piping pictures so without further adieu here they are...
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #2 Re: Intercooler piping pictures
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    Thank you very much I am actually doing one this weekend and this will help very much!!
    On your last photo you have the piping going through the frame it looks like, did you make that cut yourself or was there already a hole made for something else?
  3. #3 Re: Intercooler piping pictures
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by Loftus1995 View Post
    it doesnt go through the frame just through the unibody right outside the frame rail. IIRC i used a 3 to 3.5 inch holesaw to drill it out or i might have used my boss's plasma i cant remember. but a holesaw should work well.
  4. #4 Re: Intercooler piping pictures
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    looks amazing
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  5. #5 Re: Intercooler piping pictures
    GTP Level Member
    Jan 2015
    Lincoln, NE
    thank you. it took some time and effort but is much better then what it replaced.
  6. #6 Re: Intercooler piping pictures
    Mar 2015
    Milwaukee
    Is there a performance downside to the outlet long pipe to the intake. Im stuck between wanting to do a f-body intake, L26 with HV3, or the wild card twin-charged but thats more research on pros n cons which Ik what to do. how if I continue naturally turbo-spirated pros-n-cons of pass intake and driver intake.
    So far I got for pass side : long ass water hose, limited access to serpentine / accessories, throttle cable routing
    driver side : long ass pipe exposed across the bottom, more pipe used, possibly more joints and potential for boost leaks.
  7. #7 Re: Intercooler piping pictures
    May 2012
    Where winter never ends
    Mine is passenger side? Anyone want to see or is it of no use?
    2000 Regal - Winter Beater
  8. #8 Re: Intercooler piping pictures
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by ADecker View Post
    Actually, I'm interested.
  9. #9 Re: Intercooler piping pictures
    hangover park IL
    compressor discharge goes downward and curves around the AC drier and between the subframe/radiator support to curve around to the IC inlet
    here you can see the 2.5" discharge pipe to 3" connection point and the routing.
    the reason is simple, i wanted the battery where it'll do the most good...weight forward and as far below the axle centerline as possible.
    a true win win when going to pass TB
    throttle body side follows the usual path up over the washer res and through to the engine bay next to the res fill.
    its tight enough that the bumper cover being removed is nice but all clamp and coupler points were laid out and setup so that only the inner tire shield and/or the headlight have to be removed to service either side.
    since i had enough foresight to know that i was gonna be doing alot of repair work for the trans... i did setup the car and build so that engine removal is simple. pipes are disconnected and left in-situ and the engine can be pulled with just the removal of the DP. no need to disconnect any turbo plumbing or hotside parts. much less chance of contamination at an oil line if you layout your setup properly.
    its not as easy as unzipping my fly but its fantastically more serviceable than many setups.
    ~James~ Psychotic Gearhead
  10. #10 Re: Intercooler piping pictures
    May 2012
    Beat me to it. Thats exactly how mine is
  11. #11 Re: Intercooler piping pictures
    hangover park IL
    on jackstands?
  12. #12 Re: Intercooler piping pictures
    Nov 2012
    Erlanger, KY
    2.5" all around.
    Since solid lower and solid upper mounts going on, skipped on the hump couplers. Bough some just in case, but never used them.
    So only 4 couplers in total. No blow offs or anything had happened to it with the maybe ~1000 miles on it, and 100+ passes at the track.
    Virtually no motor movement so worked out pretty well. I am sure once mounts wear out, i'll be hurting, but probably replace those
    somewhat regular once any wear on the bottom mounts show.
    No washer bottle, but no wipers either in the car. If I had kept it, I'd had used a FBody washer bottle up in the front where the nose holes are. Fits
    great there.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  13. #13 Re: Intercooler piping pictures
    GTP Level Member
    Jan 2015
    Lincoln, NE
    those are some good looking setups!
  14. #14 Re: Intercooler piping pictures
    Kansas City, MO
    Frigging right guys. I'm brainstorming on something and this is exactly what I need to see.
  15. #15 Re: Intercooler piping pictures
    Topeka, KS
    So batt relocated to trunk?
    Sent from my SCH-I545 using Tapatalk
  16. #16 Re: Intercooler piping pictures
    Nov 2012
    Erlanger, KY
    Mine is moved to trunk now.
  17. #17 Re: Intercooler piping pictures
    Antioch, IL
    stock cartuning ftw?
    Untitled by smetters20, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  18. #18 Re: Intercooler piping pictures
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    pictures are all broken
  19. #19 Re: Intercooler piping pictures
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I'll fix them later
  20. #20 Re: Intercooler piping pictures
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  1. Replies: 19
    Last Post: 10-08-2014, 10:06 AM
  2. Best place to get intercooler tubes/piping?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 10-03-2014, 11:24 AM
  3. exhaust piping
    By backinblackgtp in forum General Tech Discussion
    Last Post: 04-09-2010, 12:24 PM
  4. intercooler piping
    By Viperhunter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2009, 04:49 PM
  5. Finally, decent pictures of my new Intercooler Reservior.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 09-16-2008, 01:18 PM
