Thread: Which Intercooler?
Results 1 to 15 of 15
  1. #1 Which Intercooler?
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Trying to figured out which intercooler to go with for my twincharged build. Here is what I've got: L67, Gen V Blower, T67 Turbo, ST5 Cam, Intense Stage 3 heads. Also, what size piping should I go with? 3" or 2.5"?
    http://www.treadstoneperformance.com...rcooler++666HP
    http://www.treadstoneperformance.com...rcooler++860HP
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  2. #2 Re: Which Intercooler?
    Kemmerer, Wyoming
    Bigger is always better, but unless you have an air to water, the air to air will only cool the air so much until the supercharger reheats the air
    2.5 inch is good for something like 1000 hp
    One more edit, a vertical flow ic is more efficient
  3. #3 Re: Which Intercooler?
    huh how in the hell is a vertical flow more efficient that blowing straight through on an air to air bar and plate IC?
  4. #4 Re: Which Intercooler?
    Kemmerer, Wyoming
    Research it yourself
  5. #5 Re: Which Intercooler?
    May 2012
    Where winter never ends
    Pretty sure water has a much higher coefficient of heat transfer than air. Hency why motors are water-cooled now days.
    2000 Regal - Winter Beater
  6. #6 Re: Which Intercooler?
    ninja edits are gay just like the over moderation don't hurt anyone's feelings on this forum.......
    Now this thread makes no sense got decker talking about air 2 water in an air 2 air thread and marshall being a dork talking about vertical intercoolers when he apparently didn't read or open any of the links in the OP's 1st post.
    Good job now this thread looks all bi polar and random
  7. #7 Re: Which Intercooler?
    Sooo um since this went full retard someone explain why bothering to use a vertical air 2 air intercooler would be worth it for the op' setup with inlet and outlet on opposite ends.
    Are the vertical intercoolers cheaper?
    Id stick with what plenty of people have used before...... come to think about it I don't think ive ever seen a vertical ic on a turbo setup.
    does that mean it wont work? No. Is it worth it? Who knows. I highly doubt anyone is going to test horizontal vs vertical anyways.
  8. #8 Re: Which Intercooler?
    hangover park IL
    up/downflow IC's are more even with temp distribution and cooling airflow, however our core support/headlights and unibody rails constrain us to lower pipe connections, a verticle flow core would end up with some major compromises on piping or require a tubular frontend to gain routing options.
    we aren't as lucky as the vette/Fbody guys to have the airflow path over the radiator/core support.
    everything is a compromise. our discharge piper is 2" so we can wrap around the AC drier and get to the IC below and around the core support. just so we could keep the battery up front where the weight helps us, and to keep frosty AC....
    ~James~ Psychotic Gearhead
  9. #9 Re: Which Intercooler?
    hangover park IL
    headlight delete?
  10. #10 Re: Which Intercooler?
    Kemmerer, Wyoming
    these are the two intercoolers I am considering if I ever put the turbo on my car:
    http://www.treadstoneperformance.com...rcooler++500HP
    http://www.treadstoneperformance.com...rcooler++720HP
    vertical flow intercoolers flow more air and have less pressure drop than horizontal flow. that is why the cores don't need to be as big.
  11. #11 Re: Which Intercooler?
    hmm weird both intake and discharge on the same side........
  12. #12 Re: Which Intercooler?
    Nov 2012
    Erlanger, KY
    I run this...
    http://www.treadstoneperformance.com...cooler++1000HP
    I used 2.5" all around.
    I don't have AC ... but the battery moved down and fbody intake and junk, the pipe work we made cleared everything,
    so I could have kept AC... but it was dead when car was bought so out it went. Plus, less weight :P
    Bigger is always better in this case. I went with the much bigger than really needed intercooler in the hopes that it would not
    get as heat soaked at the track. I did in the summer, back to back to back runs with in a tenth of each other. And get back to the pits, and
    its pretty cool to the touch considering....
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  13. #13 Re: Which Intercooler?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    I use the treadstone TR1245.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  14. #14 Re: Which Intercooler?
    Bastard Reptile's Avatar
    Kansas City, MO
    holy **** that pcm placement. LOL
  15. #15 Re: Which Intercooler?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Was thinking the same thing!
  1. Intercooler core, intercooler parts. Bonneville SSEi parts.
    By oldsman105 in forum For Sale - Parts
    Last Post: 03-23-2016, 04:59 PM
  2. Intercooler lower intake manifold without intercooler
    By GPChief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 02:35 PM
  3. Intercooler set ups - what to go with
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-28-2012, 11:50 AM
  4. looking at getting the ZZp intercooler need some help.
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2011, 07:33 PM
  5. zzp intercooler vs wbody store intercooler ?
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 05-04-2010, 02:40 AM
