Thread: IAT Resistor anti-lag anyone?
Results 1 to 3 of 3
  1. #1 IAT Resistor anti-lag anyone?
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Im pretty sure people have done this in the past. Is there a write up on how to make the anti-lag switch using a relay and some resistors?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: IAT Resistor anti-lag anyone?
    Nov 2012
    Erlanger, KY
    Just need a momentary switch either you hold and press.. or rig up to brake pedal.
    When pressed in, cuts signal of IAT...
    Drops to -39
    Adjust your IAT table to knock timing down to nothing.
    when you let go of switch, IAT is back to working order and timing restores to normal.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  3. #3 Re: IAT Resistor anti-lag anyone?
    Apr 2014
    South Haven, MI
    Well that seems simple enough. Thank you.
  1. anti shake kit help!
    By Alix0r in forum Visual/Body Modifications
    Last Post: 11-23-2013, 05:31 PM
  2. im pretty much anti-20's but
    By TorqueAutoMotiv in forum Tires & Wheels
    Last Post: 05-12-2010, 10:03 PM
  3. Anti Freeze Leak
    By JB381 in forum General Tech Discussion
    Last Post: 02-26-2010, 09:00 PM
