Thread: Vacuum line routing with an m90 block off
Results 1 to 6 of 6
  1. #1 Vacuum line routing with an m90 block off
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Does anyone have a diagram on how to run the vacuum lines on a car running an m90 block off plate?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Vacuum line routing with an m90 block off
    Kemmerer, Wyoming
    Why would it be different
  3. #3 Re: Vacuum line routing with an m90 block off
    Quote Originally Posted by SgtMarshal View Post
    What he said.
  4. #4 Re: Vacuum line routing with an m90 block off
    Apr 2014
    South Haven, MI
    I was referring to where to add the line for the turbo and wastegate.
  5. #5 Re: Vacuum line routing with an m90 block off
    Kemmerer, Wyoming
    Car tuning has instructions on their website
  6. #6 Re: Vacuum line routing with an m90 block off
    Antioch, IL
    Just tee into a vac line
    I have waste gate hooked up to the vac line in the back, boost controller is hooked up to the vac nipple that used to hook up to the sc bbv. BOV is hooked up to a T that goes to the FPR
    2009 Challenger SRT8
    Expert at being gay.
  1. Vacuum routing/lines
    By Runicdionysus in forum Turbo
    Last Post: 10-27-2015, 07:46 PM
  2. Vacuum line routing..
    By Ridin ON Chrome in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2015, 07:48 PM
  3. Gen V with L67 throttlebody need vacuum routing pics
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2011, 09:15 PM
  4. L67 vacuum routing HELP!
    By thunder71173 in forum General Tech Discussion
    Last Post: 04-02-2011, 06:33 PM
  5. looking for a vacuum line routing guide
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 12:02 PM
