Re: Pulsing the turbocharger...
jbunla
Nocutt do you care to talk more about the difference in headers on the thread. Like tunned headers with a turbo, I also see this big debate all the time over headers and logs in terms of turbo and so many people claim there is a difference others argue not much.
No point...
The only issue for me at least is that many ppl are approaching it from a linear perspective (and unfortunately kit mentality creates this somewhat), which is fine but very limited. Head, Cam, turbine and exhaust system are built together. You look at the Cam events (especially the EVC) and move from there; this builds on the characteristics of the said engine (imo)...the how if you will, is picking the right turbo (again as a system, turbine match the compressor...the housing to put you were u wish to make power).
There is a turbo in the exhaust path, you really cannot get too much from tuning it (if we are talking things like negative pressure/scavenging etc, etc)...again for a street car where a broader rather than a peaky curve is much more suitable.
The debate of logs vs headers is really an old one, which was actually based on 80's (and lower yrs) exhaust manifold (and to a point camshaft) technologies. With today's metallurgy and new tech it is really just packaging that because the real issue...not the type of turbo application nor the type of manifold used if one actually knows what they r doing...
Personally if I ever have to do this again...I will actually look into a cam with a slight overlap, home port job...and get a even larger divided turbine housing and go from there.
