Thread: Relocated WG to Xover on Cartuning Kit
Results 1 to 10 of 10
  1. #1 Relocated WG to Xover on Cartuning Kit
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Well I kinda still have a CT kit. I have the xover, upper DP and lower DP still.
    So to help me with the new Chris Hinson heads I wanted to upgrade my exhaust somehow to also help let the engine breath.
    I ordered a ZZP rear plog. With that I have to relocate the WG. Only spot was on the xover by the turbo. Going to use a flexible dump pipe since the one I had made up won't fit. Dump pipe needs/should to me made with xover and WG flange on the car.
    I just need to wrap the radiator hose since it's close to WG.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: Relocated WG to Xover on Cartuning Kit
    Wow, that looks interesting. Never seen one mounted so far forward or near the rad hose. I'm sure you'll keep an eye on it the first few outings just in case!! The joy of modding, things always happen when you think you've thought of it all! Good work!
    I had wrapped my front powerlog when I first got it, but it cracked within a month... Now I'm pretty skeptical about wrapping exhaust in general. You had any issues?
  3. #3 Re: Relocated WG to Xover on Cartuning Kit
    Feb 2008
    NY
    Thx. Never done modding. Lol
    I have my front and rear plog ceramic coated but actually coated. Not with a spray can. Those aren't wrapped. I have the xover and upper DP wrapped. Those are spray ceramic coated. Never an issue.
  4. #4 Re: Relocated WG to Xover on Cartuning Kit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i relocated my gate as well but i put it where the EGR was like most of the other kits out there. looks interesting. are you going to have any issues with the unmetered exhaust from the dump tube?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  5. #5 Re: Relocated WG to Xover on Cartuning Kit
    Kemmerer, Wyoming
    Quote Originally Posted by NebTurboST5 View Post
    Did you use an adapter to move the wastegate, and if so which one.
    http://m.ebay.com/itm/261993395614
    I was looking at this but I don't think there is enough space
  6. #6 Re: Relocated WG to Xover on Cartuning Kit
    Feb 2008
    NY
    No exhaust flow measuring is needed for dump pipe?
    My sensors measure air fuel ratios in the exhaust.. not flow.
  7. #7 Re: Relocated WG to Xover on Cartuning Kit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i guess the correct way to ask the question would be. is the open dump pipe going to affect the reading on the wideband? i dont know i have never dealt with one.
  8. #8 Re: Relocated WG to Xover on Cartuning Kit
    Feb 2008
    NY
    as the exhaust going out the dump.. and going into the turbo.. is all the same air/fuel exhaust mixture. once exhaust out of the heads.. the mixture should pretty much be the same through out the exhaust gasses
  9. #9 Re: Relocated WG to Xover on Cartuning Kit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    yeah i guess it wont matter even for the narrowbands either since the gate should really only be open when they arent doing anything anyway....carry on.
  10. #10 Re: Relocated WG to Xover on Cartuning Kit
    GTP Level Member
    Jan 2015
    Lincoln, NE
    The adapter I used was my millermatic 251...
  1. Transmission parts...GMR, Cartuning etc
    By GTPpower in forum For Sale - Parts
    Last Post: 03-26-2015, 12:56 AM
  2. Cartuning Turbo on 05 GP GXP
    By gxpmike05 in forum 5.3L V8 (LS4)
    Last Post: 06-23-2013, 11:31 AM
  3. Relocated to Rock Hill SC
    By CalEditor in forum Southeast
    Last Post: 05-17-2010, 10:00 PM
  4. pics of relocated pcm?
    By JoelW98GTP in forum General Tech Discussion
    Last Post: 11-22-2009, 12:39 PM
  5. cartuning
    By 1998xGTP in forum Turbo
    Last Post: 10-19-2009, 11:47 PM
