Thread: intercooler design
Results 1 to 20 of 21
  1. #1 intercooler design
    Kemmerer, Wyoming
    why is this so much smaller but still supports about 550 hp
    http://www.ebay.com/itm/181879788011...%3AMEBIDX%3AIT
    than this intercooler
    http://www.ebay.com/itm/170805189998...%3AMEBIDX%3AIT
    is it just a marketing gimmick to say how much hp the intercooler can support?
  2. #2 Re: intercooler design
    Bar and Plate vs Tube and Fin
  3. #3 Re: intercooler design
    Kemmerer, Wyoming
    is there that big of a difference between the two different styles?
  4. #4 Re: intercooler design
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Bar/Plate is what you want. Looks like both are bar/plate although smaller in size the thickness plays a big role. (That's what she said....zing!!)
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: intercooler design
    Kemmerer, Wyoming
    the one with the straight through flow is a tube and fin
  6. #6 Re: intercooler design
    GXP Level Member
    Mar 2015
    Tomball
    Tube and fin is like a regular regulator, Bar and plate are typically thicker and have fins on the inside of the tube as well to aid in heat transfer, therefore they are more efficient at removing heat.
    Jeff
  7. #7 Re: intercooler design
    Kemmerer, Wyoming
  8. #8 Re: intercooler design
    GXP Level Member
    Mar 2015
    Tomball
    Good lord, for that price it would make a great FMHE.
    Jeff
  9. #9 Re: intercooler design
    Kemmerer, Wyoming
    It's a reasonable size and really cheap
  10. #10 intercooler design
    Quincy, Mass
    I got mine at frozen boost, 2.5" piping, I use a z7 piping kit and modified it a little to fit right. I also had to trim my drivers fog light housing a bit at the top.
    No more GP 04 Impala SS Indy:
  11. #11 Re: intercooler design
    Kemmerer, Wyoming
    did you put the front bumper back in?
  12. #12 Re: intercooler design
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    This is the size of the one that I have for sale in my posting. Got it from CXRacing. If you need one.. let me know. It is a bar/plate style. That is what you want.
  13. #13 Re: intercooler design
    Kemmerer, Wyoming
    Quote Originally Posted by DJNight2k View Post
    Taking the supercharger off and putting the N/A upper and lower intake manifold on has been a pain in my butt. To begin, I tapped and plugged the injector holes on the L36 lower intake. When I installed the manifolds, the L67 fuel rails would not clear the upper manifold, and the injector's would not make a vacuum seal in the injector bungs. Therefore, I extended the fuel rails with some 300-psi fuel injector line and a couple fuel injector hose clamps. I thought by extending the rails I would have got the angle I needed for the injectors to seal in the bungs on the heads. I am sure the L36 lower manifold is covering the injector bungs in the heads too much for the injector's to seal, so I am thinking I need to take them off and do some grinding on the lower manifold for more clearance.
    Therefore, before I make any more purchases for turbo parts, I need to get this problem resolved.
  14. #14 Re: intercooler design
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    Shoot me a pm if interested in custom Aussie fuel logs for use with L67 heads.
  15. #15 Re: intercooler design
    hangover park IL
    make sure you are putting the injector to rail retainer clip into the correct slot on the injector.
    ~James~ Psychotic Gearhead
  16. #16 Re: intercooler design
    Kemmerer, Wyoming
    Quote Originally Posted by Turbocharged400sbc View Post
    if I didn't do that, there wouldn't be a vacuum leak?
  17. #17 Re: intercooler design
    Bastard Reptile's Avatar
    Kansas City, MO
    That would probably cause a fuel leak.....well, definitely a fuel leak.
  18. #18 Re: intercooler design
    hangover park IL
    I've seen it before. Twice. on some applications the injectors have multiple grooves. I have seen people put them in the wrong groove and the cylinder head o ring is approximately 1 o ring thickness too far out of the cylinder head.
    It's something to check.
  19. #19 Re: intercooler design
    Kemmerer, Wyoming
    Quote Originally Posted by Reptile View Post
    it didn't actually leak, I haven't put the clips back on yet, and have had the car running a few times. I've olny driven it around the block though, and do plan on putting the clips back on very soon.
    the fuel injector groove on the bottom only has one location for an o ring. let me see if I can find a picture to illustrate what's going on.
  20. #20 Re: intercooler design
    hes means the top of the injector, it has a small slot in it where the clip goes in and holds it to the rail.
  1. Intercooler lower intake manifold without intercooler
    By GPChief in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2015, 02:35 PM
  2. converting tranny cooler lines from 1st design to 2nd design
    By tonglebeak in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2012, 08:16 PM
  3. Belt Question, 1st design or 2nd design?
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2012, 01:10 PM
  4. 1st Design or 2nd Design Water Pump?
    By BlackGT1 in forum General Tech Discussion
    Last Post: 04-22-2012, 11:16 PM
  5. New Intercooler Design Phenolic Core
    By minichopper6hp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2011, 12:52 AM
