Thread: Turbo Questions
Results 1 to 6 of 6
  1. #1 Turbo Questions
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Ive decided to start a thread on this. I searched and found some answers but id like to hear some opinions as well.
    Ill start with fueling first.
    I plan on trying to make around 450 whp this year on e85. Will 60# injectors and a 255 lph pump be enough?
    Second is vacuum line routing.
    Does anyone have a diagram of how vacuum lines are supposed to run with an l26 intake manifold?
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Turbo Questions
    Antioch, IL
    80# injectors
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Turbo Questions
    Apr 2014
    South Haven, MI
    I found a thread on here that mentions the install of a 430 LPH pump. I may give that a try or just run the racetronix kit made for the w-body.
  4. #4 Re: Turbo Questions
    hangover park IL
    we did 608 lean as hell maxing out the 255 and 90's
    youll be fine with a 255 and 90s
    ~James~ Psychotic Gearhead
  5. #5 Re: Turbo Questions
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Buy My fuel pump.. Highflowfuel 255lph, outflows a walbro. In a venturi bucket and a new gm level sensor and extra clamps for the hard line to replace the worm clamps that some have had issues with. asking $200. I would agree with the others, if you are going e85, probably want to go 80lb injectors.
  6. #6 Re: Turbo Questions
    Apr 2014
    South Haven, MI
    Im already on e85 and i dont want to change back over to pump gas.
  1. z3 turbo kit questions
    By Nchristopherson in forum Turbo
    Last Post: 03-16-2015, 11:02 AM
  2. Cartuning Turbo Kit questions. Need Help.
    By GTPMidknight in forum Turbo
    Last Post: 02-24-2015, 07:45 AM
  3. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  4. turbo questions
    By soocold in forum Turbo
    Last Post: 11-10-2009, 07:43 PM
  5. Turbo Questions
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2009, 02:26 PM
