Thread: Not enough vacuum for brakes?
Results 1 to 20 of 29
  1. #1 Not enough vacuum for brakes?
    May 2014
    New Mexico
    Turbo kit all put together and running good. Had to get the smaller brake booster from zzp to fit the 3" DP of course. but now the brakes are ROCK HARD. It stops, but with an insane amount of effort. First though was to bleed the brakes, no change. Couldn't figure anything else out so I took it to the performance shop we have here in Albuquerque to let them tinker with it. After a few weeks they're now telling me that I don't have enough vacuum at idle for the brakes and said I need to install an electric vacuum pump. they told me that when they add more vacuum with a pump the brakes come back and work normally. Anyone had this problem before? Is their another way to fix it besides spending $400 on a pump?
    Thanks.
  2. #2 Re: Not enough vacuum for brakes?
    whats your set up intake wise? if you pull the vac line off the booster is there vacuum?
    maybe you got a beat booster?
  3. #3 Re: Not enough vacuum for brakes?
    Kemmerer, Wyoming
    Did you block your pcv when you put the turbo in?
  4. #4 Re: Not enough vacuum for brakes?
    Nov 2012
    Erlanger, KY
    Something not right. I run the smaller brake booster and it stops me just fine at the track with traps at 135mph.... on stock brakes too.
    Either vac leak, or using a hose that is collapsing? or the checkvalve is bad?
    Either way something is not right in your setup.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  5. #5 Re: Not enough vacuum for brakes?
    Antioch, IL
    Me thinks you didnt bleed the master correct, my truck did the same thing, after correct bleeding it was fixed.
    2009 Challenger SRT8
    Expert at being gay.
  6. #6 Re: Not enough vacuum for brakes?
    Quincy, Mass
    Did you buy a used booster?
    No more GP 04 Impala SS Indy:
  7. #7 Re: Not enough vacuum for brakes?
    Dec 2011
    colorado
    Would something like this keep the brakes from holding when trying to brake boost? When i try to build boost i just roll through the brakes.And they do not stop very good when hard braking. They are corvette callipers and rotors so I would think they would hold good. Thanks for any advise
  8. #8 Re: Not enough vacuum for brakes?
    got the calipers on with the bleeders up?
    mushy pedal is a bad master, a leak, or needs to be bleed, hard pedal is the booster not working. or not getting vacuum.
    turn the car off pump the pedal, it gets hard, thats what no vacuum to the booster feels like.
  9. #9 Re: Not enough vacuum for brakes?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    I have an st5 cam and it only pulls 14 inhg at idle and mine stops fine too with a small booster and f body brakes. The first small booster I had was **** and the brakes were insanely hard
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  10. #10 Re: Not enough vacuum for brakes?
    Dec 2011
    colorado
    The front 2 calipers have the bleeder facing down the rears are up. The pedal is defanatly not hard. It is kinda soft now that I really pay attention. Do I need to swap the calipers and then bleed them? I don't see that I have a leak anywhere. Thanks for the help
  11. #11 Re: Not enough vacuum for brakes?
    yup. you messed up the install. flip each caliper to the other side of the car, bleeders up, re bleed, you'll be good as new.
    pretty common f up. just need to keep in mind if the bleeder is not up, air cant get out.
  12. #12 Re: Not enough vacuum for brakes?
    Dec 2011
    colorado
    Awesome man thanks alot for the help
  13. #13 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    Finally getting back to this post months later... I had some family stuff come up and had to put the GP on hold for a quite a while. I've figured out with 98% certainty it's the booster. Just getting back into it now. Now when Depressing the brake pedal you can hear an air leak type of noise and the RPMs jump up. Figure the diaphragm in the booster is ripped or damaged and is causing a vac leak. I'll be ordered another one from ZZP soon and see if that correct the problem.
  14. #14 Re: Not enough vacuum for brakes?
    if you pump the brakes you will hear a hiss, and the rpms will go up,,,why you ask? cause your took vacuum from the engine to re fill the booster.
  15. #15 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    oh well i feel dumb I didn't ever recall that happening before the turbo. Maybe I'm just looking for something to be wrong. I figure it would be best to get another booster anyway since that is most likely the issue.
  16. #16 Re: Not enough vacuum for brakes?
    if you flipped the calipers over, re bled them, all should feel good now.
  17. #17 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    I didn't even touch the calipers. Just removed the master, removed the old big booster, put in the new booster and then reinstalled the master.
  18. #18 Re: Not enough vacuum for brakes?
    Antioch, IL
    fix the calipers and re bleed then, make sure the master is done properly, you cant just add fluid and be on your mary way
  19. #19 Re: Not enough vacuum for brakes?
    Quote Originally Posted by Runicdionysus View Post
    if you have not flipped your calipers over yet,,,,,why are you posting about the booster again? fix the calipers, life will be good again.
  20. #20 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    I'm sorry I'm confused. After installing a smaller brake booster it is necessary to flip the brake calipers over and bleed them? What exactly does flipping them over mean? is it literally unbolting them and turning them upside down? lol
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  3. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
  4. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
