Thread: Not enough vacuum for brakes?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Not enough vacuum for brakes?
    did you not say you installed f body brakes and the bleeders are on the bottom??? if so the calipers are on the wrong sides, you cant bleed them nipple on the bottom. has to be pointed up.
    take them both off, and swap sides, then bleed the brakes again.
  2. #22 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    No Sir that was Mike Kulp that said he has Corvette calipers.. I'm the OP.
  3. #23 Re: Not enough vacuum for brakes?
    got the calipers on with the bleeders up?
    mushy pedal is a bad master, a leak, or needs to be bleed, hard pedal is the booster not working. or not getting vacuum.
    turn the car off pump the pedal, it gets hard, thats what no vacuum to the booster feels like.
    back to this quote then, pull the vac line off the booster, see if you got vacuum on the line, car should stall once it open to air.
    Quote Originally Posted by Runicdionysus View Post
    im a dope, need to read more gooder
  4. #24 Re: Not enough vacuum for brakes?
    hangover park IL
    OEM brake hose can collapse under a WOT to closed throttle/engine braking transition...say after a burnout....when manifold vac spikes
    ~James~ Psychotic Gearhead
  5. #25 Re: Not enough vacuum for brakes?
    Donating Users moddman's Avatar
    Midwest
    Quote Originally Posted by Turbocharged400sbc View Post
    I seen this before happen on my relatives car. Good thing to check it out. ( Btw: Turbo400SBC Check your messages.)
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  6. #26 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    I will check that when I get home. I should also mention that the brakes work good when the car is in higher rpms, but down at idle they get rock hard. however if you're cruising at 2k+ rpms the brakes get life back into them. as the RPMs drop they get harder and harder
  7. #27 Re: Not enough vacuum for brakes?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    That's cause under decel the engine pulls more vacuum
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  8. #28 Re: Not enough vacuum for brakes?
    hangover park IL
    hard decal/engine braking = highest manifold vac readings....most likely to cause hose to collapse
  9. #29 Re: Not enough vacuum for brakes?
    May 2014
    New Mexico
    Not hard deceleration at all. This is very normal driving/ grandma driving. I pulled the hose and it definitely has vacuum. I'm definitely thinking booster
  1. Brembo brakes or f-body brakes? Any other choices?
    By LAST2DOOR in forum Brakes/Suspension/Chassis
    Last Post: 09-26-2013, 10:37 PM
  2. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  3. Brakes squealing even after foot is off brakes
    By GTLGDP in forum General Tech Discussion
    Last Post: 06-26-2012, 09:16 PM
  4. vacuum
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 10-05-2009, 09:09 PM
