Thread: Those of you with a Stattama/3" DP...
Page 1 of 3 123 LastLast
Results 1 to 20 of 58
  1. #1 Those of you with a Stattama/3" DP...
    Never Never Land
    The car this setup is going in is a 97 GTP. I've read I need a smaller brake booster. That's no biggie.
    I've also read I might have issues with the ABS block since it's a 97. Anyone ran into this or can shed some light?
    Thanks
    EDIT: Found these pics of Alex's car. I talked to Alex about it about a year ago and he said he deleted the ABS but the ABS is there in these pics so maybe I'll be okay? These are the same pics in post 35. I added them here so they're more likely to be seen.
  2. #2 Re: Those of you with a Stattama/3" DP...
    if your abs pump is bolted to the master the 4 hard lines may not like being moved to far. you know old and rusty.
  3. #3 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    Right. I'm just curious if the downpipe will actually fit. And if it doesn't what I have to do about it wether it's convert to newer stuff or delete the ABS all together although I'd rather not do that.
  4. #4 Re: Those of you with a Stattama/3" DP...
    from pics ive seen its the master end thats close to hitting. the Monte booster is supposed to make it clear better.
  5. #5 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    Do you happen to know where any pics are I could look at? I seem to never be able to find too many pics
  6. #6 Re: Those of you with a Stattama/3" DP...
  7. #7 Re: Those of you with a Stattama/3" DP...
    May 2012
    Where winter never ends
    The smaller booster should let the master clear; however, I had to move the pump to make it all fit.
    2000 Regal - Winter Beater
  8. #8 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    Info on moving that?
  9. #9 Re: Those of you with a Stattama/3" DP...
    I suggested deleting the ABS but you're a pansy
  10. #10 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    no real man needs an anti badass system
    ~James~ Psychotic Gearhead
  11. #11 Re: Those of you with a Stattama/3" DP...
    May 2012
    Unbolt it, move it to where it will fit, rebolt it.
    Your going turbo, break out your common sense and problem solving skills!
  12. #12 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    ...and wallet
  13. #13 Re: Those of you with a Stattama/3" DP...
    and booze
  14. #14 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    ...and fire extinguisher
  15. #15 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    abandon hope all ye who turbo here
  16. #16 Re: Those of you with a Stattama/3" DP...
    At least everyones wasted
  17. #17 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    like all my time and money....
  18. #18 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    I'd consider deleting it. Was it an option to get a GP without ABS?
  19. #19 Re: Those of you with a Stattama/3" DP...
    id like to see how one pulls that off in a 97/98. the abs is bolted to the master, and the abs has 4 lines off it.
    looks like this.
  20. #20 Re: Those of you with a Stattama/3" DP...
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by PurpleGuy View Post
    No, all came with it standard.
  1. Still getting "Check Security System" and got "Battery Saver Mode"
    By J57ltr in forum General Tech Discussion
    Last Post: 08-08-2015, 01:36 AM
  2. How to properly reset "shift learn" or "adapt" in 4t65e-HD
    By AndrewGXP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2015, 09:30 PM
  3. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  4. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
