Thread: Those of you with a Stattama/3" DP...
Results 21 to 40 of 58
  1. #21 Re: Those of you with a Stattama/3" DP...
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    id like to see how one pulls that off in a 97/98. the abs is bolted to the master, and the abs has 4 lines off it.
    looks like this.
    GM arranged that "generation" I guess you could call it, horribly. Air box gives less horsepower and everything is in places it doesn't need to be.
  2. #22 Re: Those of you with a Stattama/3" DP...
    Quote Originally Posted by StayFree View Post
    No, all came with it standard.
    not true, some came with no abs.
  3. #23 Re: Those of you with a Stattama/3" DP...
    Apr 2015
    I've never heard of anyone or seen anyone without it...
  4. #24 Re: Those of you with a Stattama/3" DP...
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I believe the 03 Model year could be ordered wtihout ABS
  5. #25 Re: Those of you with a Stattama/3" DP...
    Apr 2015
    Oh wait, after some reading, I guess in 2003 it was an option on SE and GT models. My bad.
  6. #26 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    Either way. How would one go about either deleting it of converting to 99+?
  7. #27 Re: Those of you with a Stattama/3" DP...
    Apr 2015
    Quote Originally Posted by PurpleGuy View Post
    It would be kind of tricky. You'd have to somehow block all the lines, and trick the computer into that it still has it so you still have traction control.
  8. #28 Re: Those of you with a Stattama/3" DP...
    Apr 2015
    I keep imaging doing this on the '99-'03 engines, I've never first hand seen what your ABS set up looks like.
  9. #29 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    It's a 97. It doesnt have TCS. Even if it did it would be tuned out.
  10. #30 Re: Those of you with a Stattama/3" DP...
    Apr 2015
    In that case, this is the only way I could possibly think of deleting your ABS. First, unbolt the ABS control unit from the master cylinder, plug the hole to the master, pull all the ABS lines. Not sure of they go right into the caliper or what, if they do, plug the holes in the caliper, and that's all I could think of. I'm not sure if it would be worth it. And don't follow this! I've never done this, this is the only way I could come up on how to do it.
  11. #31 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    youll need to find that setup off the 93/94+ bonnies/caddy's (they used the newer systems before the W did in 98ish) that have the remote mounted setup (thats the delco IV that has the gear falling off issue iirc)
    early 4th gen F bodies as well, they are probably closer to what you need
    from what i recall there was a 4 inlet and a 2 inlet system, both require the 2 or 4 port masters with threaded fittings (that system uses the O rings) and if its the 2 port youll need the inline rear brake proportioning valves or a jegs/wilwood/etc adjustable unit.
    ~James~ Psychotic Gearhead
  12. #32 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    at the least you need this block that mounts to the delco IV and the later GP two port master of the diameter of your choosing
    http://www.ebay.com/itm/93-97-Firebi...-/381227373144
  13. #33 Re: Those of you with a Stattama/3" DP...
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    I haz a pretty nice Monte/impala brake booster I'd sell. $35 plus shipping?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  14. #34 Re: Those of you with a Stattama/3" DP...
    nicopp line is your friend so is a nice flaring tool.........
    i vote putting that abs system in the same place as all a2w intercoolers...... in the fvcking trash can!!!! hahahaha!!
    do it dont be a puss.
    Edit 2nd option throw away 97 car keep turbo kit for different car. lololololololol!!
    Edit again. 3rd option requires being a man and you get to keep stock booster and abs sh1t. turbo pipe through the hood like a boss who needs exhaust on a turbo car?
  15. #35 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    I went diggin through Alex's pics and found these couple. I talked to him probably about a year ago and he said he deleted the abs but in these couple pics the abs is still there. So maybe I'll be okay?
  16. #36 Re: Those of you with a Stattama/3" DP...
    Never Never Land
    Quote Originally Posted by ImNowTylerTibbets View Post
    Option 4: Tyler buys all my turbo and engine stuff and I just don't do it?
  17. #37 Re: Those of you with a Stattama/3" DP...
    Antioch, IL
    "3 inch 304 stainless downpipe (97 owners will need to remove their ABS system)
    -Small diameter brake booster"
    CT kit with 2.5"DP visualize it
    Untitled by Corey S, on Flickr
    2009 Challenger SRT8
    Expert at being gay.
  18. #38 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    you can take the Impala brake booster cut the lower two tabs that hold the bracket to the body and weld in a 3/16 chunk of steel and it will angle the whole assembly up over half an inch at the downpipe.
  19. #39 Re: Those of you with a Stattama/3" DP...
    hangover park IL
    I should clarify that you're cutting and welding on the bracket that is riveted to the back of the Impala brake booster.
  20. #40 Re: Those of you with a Stattama/3" DP...
    deal send me your paypal and ill send the 500 right away lol thanks!!
    whats better than 1 turbo kit laying in my basement? well thats easy, 2 turbo kits laying in my basement of course!!!!
  1. Still getting "Check Security System" and got "Battery Saver Mode"
    By J57ltr in forum General Tech Discussion
    Last Post: 08-08-2015, 01:36 AM
  2. How to properly reset "shift learn" or "adapt" in 4t65e-HD
    By AndrewGXP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2015, 09:30 PM
  3. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  4. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
