After months and months of searching for a reputable company that gives not only one of the best warranties in the industry but also a lockup clutch that was specifically designed for PWM TCC operation, We are proud to announce that we offer high performance stall converters for the 4T60E/4T65E. Since we are working with a major performance converter company every converter, like our transmissions, is built specifically for YOUR application, not the shelf. These converters are rated up to 650 HP levels and carry a full 2 year warranty! These stall converters are not designed for WOT lockup and will retain stock lockup operation that will not require special pcm tuning. The torque converters will have a base cost of $574.95 plus shipping. These will be a 245mm based converter so a drilled L67 flexplate, L36 flexplate, or Billet flexplate with correct hole pattern will be required. Our upgraded converter over this one features a custom machined billet steel back cover that has a dual bolt pattern to work with either flexplate and also features a special custom sized larger lockup clutch disc for greater durability, and due to the nature of the construction is much stronger and wont have the deflection under severe loads like a stock cover will have. These torque converters are $749.95. As I have mentioned several times over the years, a good quality converter is not cheap and you can be assured that you will be buying a top quality converter that last a long time, handle big HP, and retain great lockup operation. Build time is typically 3-5 days plus shipping time. For any questions or order info please email us a Tripleedgeperformance@comcast.net. Vehicle, engine, and transmission information IS REQUIRED before any order is processed!!!
