Thread: 2007gxp
Results 1 to 1 of 1
Threaded View
  1. #1 2007gxp
    Aug 2016
    Illinois
    I am a new owner of a 2007 gxp that has a chattering like noise coming from the trans I believe
    Once it downshifts to first gear as I stop it goes away
    Help ?
    Any ideas?
    Supposedly the car had a new converter and shift kit installed right before I got the car
    I took the surpenteen belt off to make sure nothing there was the noise
    I have stopped each wheel seperatly and once the trans shifts into a higher gear the noise starts its not the motor or the hub bearings
    It must be in the trans but in not sure what else to try
    The noise does not imediatly start
    30 sec or so it starts
    It sounds a lot like a idler pulley bearing to me
    The noise is coming from the passenger side
