Thread: Twin Engine GTP First runs at the dragstrip !
Results 1 to 20 of 25
  1. #1 Twin Engine GTP First runs at the dragstrip !
    GTP Level Member TwinV6GTP's Avatar
    May 2013
    Gatineau
    In order to keep my trans alive, I force them to start in 2nd gear. It's easier on parts not having to shift to 2nd gear.
    It worked very well in the 11.0 Parts car.
    So I figured I do in the Twin Engine. On the street the car hooked so hard it was unreal. The little wheel spin helped launch it hard.
    At the strip the 2nd gear launch needed a lot of boost to be effective especially on the rear engine.
    I did no burnout for my 2 passes.
    1st pass ever in the car with a low boost launch and no spin
    10.0 @ 140 mph
    With a slow 1.7 60 foot (normally 1.5 on the street)
    6.5 sec 1/8 mile @ 110 mph !
    Yes 110 mph in 6.5 seconds ! Actual mph was 112 in the GPS performance meter which shows the true speed (more accurate than the track's timers.
    It rains for a while and then the track is super slippery and still wet. I attempt a pass...
    I was spinning all four till the 1000 feet mark 3/4 way down the track. Felt amazing but lots of spin.
    2nd Pass is a 10.02 @ 141 mph !
    Incredible considering a still damp/wet track.
    2015 Custom Twin Engine Nascar style car with dual GTP 3.8 drivetrain, Front trans 4T65e-HD, Rear 4t80e trans 1/4 mile 8.38 @ 165mph
    2000 GP Twin Engine Twin TD Turbo kits. Stock engines stock trans(s) stock injectors stock MAFs 0-60mph 1.8 seconds 1/4 mile 9.72 @ 139 mph
  2. #2 Re: Twin Engine GTP First runs at the dragstrip !
    Florida
    So damn impressive its not even a joke. Give you huge props for a unique build that runs the way it does at thetrack with little work done.
  3. #3 Re: Twin Engine GTP First runs at the dragstrip !
    Oct 2011
    Toledo, OH
    This is getting ridicules I am glad to be a part of this community.
    7"
  4. #4 Re: Twin Engine GTP First runs at the dragstrip !
    May 2008
    Winnipeg, MB
    name another twin engine car you have come across
    2007 Pontiac Grand Prix
  5. #5 Re: Twin Engine GTP First runs at the dragstrip !
    Oct 2011
    Toledo, OH
    Quote Originally Posted by tod1d View Post
    Make no mistake, I don't mean ridicules in a negative tone.
    7"
  6. #6 Re: Twin Engine GTP First runs at the dragstrip !
    Ocala, FL
    Wow that's awesome, really impressive.
  7. #7 Re: Twin Engine GTP First runs at the dragstrip !
    Mar 2012
    NC
    I really want to see what this will do on a sticky track...with more boost... Damn that thing hauls!
  8. #8 Re: Twin Engine GTP First runs at the dragstrip !
    Dec 2010
    ATL,Georgia
    04 Top-swapped, 3.2 pulley, ZZP 1.9 rockers w/ #90 springs,Mild P&P heads, Pacesetter Headers, Sseilmnop 2" Phenolic Intercooler with stage 3 HE, ZZP billet fuel rails, 42.5lb injectors, 3" full exhaust, all poly mounts,other supporting mods.
    oh and weight addition mods: CTS-V brake upgrade, 14" GT500 rotors
  9. #9 Re: Twin Engine GTP First runs at the dragstrip !
    May 2013
    Gatineau
    With a 1st gear start ET would have many tenths quicker. The track was sticky at first before the rain. But I only got one run in at lower boost on the launch.
    2nd gear starts are king on the street but with the glue, I lost time off the line.
    On my 3rd run I did up the boost a little but I broke the rear input shaft unfortunately. Now I'm shopping a trans or maybe even a 4t80E swap.
  10. #10 Re: Twin Engine GTP First runs at the dragstrip !
    gardner,mass
    4t80e ftw
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  11. #11 Re: Twin Engine GTP First runs at the dragstrip !
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    that thing is crazy. very nice
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  12. #12 Re: Twin Engine GTP First runs at the dragstrip !
    GT Level Member chamberlain198437's Avatar
    Grants Pass Oregon
    Very impressive build can't wait to see what this car will run in the future... keep up the good work :-)
  13. #13 Re: Twin Engine GTP First runs at the dragstrip !
    Enfield, CT
    I'm floored! It's really nice to see you kept on with this project and the results so far are very impressive. Good Job man keep it up!
  14. #14 Re: Twin Engine GTP First runs at the dragstrip !
    GT Level Member aligater's Avatar
    london ontario canada
    Sign up for pinks all out, twin turbo 3.8l grand prix. So it's a little miss leading but I bet they like your et and think why not. Just wait till tech inspection for the raised eyebrows.
  15. #15 Re: Twin Engine GTP First runs at the dragstrip !
    SE Level Member wyoprix's Avatar
    cheyenne wy
    nice have u weighed your car yet
    2007 gt 3.0 mps 0-KR headers 3''dp cat res delete 44 injectors 85MAF stage 3 intercooler 108 t stat cold air, overkill pcm, aeroforce gauges tripple pillar, rims tint, trans cooler intense shift kit, yella terra 1.9 roller rockers 105 crow springs, 104 plugs, 7'' pioneer screen 1000 watt rockford amp an two 10" P3's cusom box & more
  16. #16 Re: Twin Engine GTP First runs at the dragstrip !
    May 2013
    Gatineau
    Quote Originally Posted by aligater View Post
    Thanks guys ! It's an incredible feeling behind the wheel. The sound is really crazy inside. The camera couldn't relay at all what it was inside the cabin.
    The acceleration at the 60 foot mark and on is something else.
    I just reviewed my high performance GPS numbers and here are the results:
    BTW at the shop the nickname for the car is Poor man's Veyron.
    So let's compare the real Veyron numbers with my Poor man's Veyron.
    These are verified actual results by a test company on the 1001HP Veyron (Bugatti's claimed numbers are better)
    Veyron curb weight (4150lbs + driver) Same as my GTP (4350lbs with driver 200lbs)
    Veyron W16 quad turbo
    0-60mph 2.9 seconds
    0-100 mph 5.9 seconds
    1/4 mile ET 10.8 @ 140 mph Car & driver
    Twin Engine GTP W12 Twin Turbo
    0-60 mph 2.4 seconds
    0-100 mph 5.0 seconds
    10.0 @ 141 mph on the 1st try ever lol
    The Newest Veyron Super Sport 1200HP is closer in acceleration but the GTP as edge until the 1/4 mile mark.
    The Veyron Obviously would walk it over 150 mph and win a top speed contest hands down but as far as usable acceleration I've got it covered.
    Poor man's Veyron wins !! haha
    Man this car will crush some numbers !
  17. #17 Re: Twin Engine GTP First runs at the dragstrip !
    Oct 2013
    Dillon MT
    Awesome build!
  18. #18 Re: Twin Engine GTP First runs at the dragstrip !
    May 2008
    Winnipeg, MB
    have you seen any other twin engine cars at the track?
  19. #19 Re: Twin Engine GTP First runs at the dragstrip !
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    How much do you have invested so far?
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  20. #20 Re: Twin Engine GTP First runs at the dragstrip !
    May 2013
    Gatineau
    10k maybe but that does count the parts car testing and i owny shop so the fab labor is less. To build one for a customer would be 18k
  1. Twin engine GTP project progress thread
    By TwinV6GTP in forum General Tech Discussion
    Last Post: 02-17-2017, 06:45 PM
  2. Twin Engine GTP doing insane launches on the street !
    By TwinV6GTP in forum Track Sessions and Kills
    Last Post: 08-10-2014, 11:54 PM
  3. Engine runs cold?
    By klaussk in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-13-2014, 10:41 AM
  4. Engine runs bad after traction control comes on then back off
    By 70cheveng in forum Brakes/Suspension/Chassis
    Last Post: 12-17-2013, 11:47 PM
  5. Engine runs like crap!
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-18-2009, 02:26 AM
