Thread: Stock 2006 GT track run
Results 1 to 10 of 10
  1. #1 Stock 2006 GT track run
    SE Level Member TurboMonte's Avatar
    Aug 2013
    Kalama
    Made it to the track on Saturday for a club bracket race.
    Best run of the night:
    60' - 2.25
    1/8 - 9.78
    1/4 - 15.18 at 92.72 MPH
    Want to start tuning it but the search function on here sucks and I can't find any info on a 05 pcm swap
  2. #2 Re: Stock 2006 GT track run
    Feb 2013
    Detroit, MI
    Will at Overkill can tune 06, I got a can tune from him
  3. #3 Re: Stock 2006 GT track run
    SWPA
    Well the 60' sucks, but I am sure you know that. Also it seemed to have fallen on its face in the top end. Did you leave O/D on by chance?
    Also, love the avatar. Howard the Duck, YEAH!
  4. #4 Re: Stock 2006 GT track run
    Swap info is as follows:
    Buy 05 PCM, install PCM, security learn = done.
    Gas gauge will read backwards.
  5. #5 Re: Stock 2006 GT track run
    Aug 2013
    Kalama
    I was running DR's too. I think it all has to do with the torque management messing with everything.
    I'm not a fan of can tunes, to many variables when it comes to tuning for optimum performance. Plus if I change something having to contact them, have them redo the tune blah blah blah too much time and hassle.
    Has anyone tried to fix the gas gauge issue with the 05 swap? My girlfriend drives the car as well and she'll forget that it reads backward and run it out of gas. lol
  6. #6 Re: Stock 2006 GT track run
    Its stock, with the prefect track prep and a cool night with super duper driver mod, seeing 14's is good.
    The torque managment doesnt really affect it as much as you think. Some people think removing it all is such a great idea........
  7. #7 Re: Stock 2006 GT track run
    GTP Level Member
    Pittsburgh
    or buy the overkill PCM and have everything work properly
    2003 SSEi,
  8. #8 Re: Stock 2006 GT track run
    But then: canned tune.
    Not cool.
    Not optimal.
    STILL WORKS, just not always the best option.
    Will figured it out...now he just needs to whore it out to people who tune
  9. #9 Re: Stock 2006 GT track run
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    INFORMATION
    Subject:
    Fuel Gauge Reads Backwards After Changing Fuel Level Sensor/Sender CardModels:
    2007 Buick Allure (Canada Only), LaCrosse
    2007 Chevrolet Impala, Monte Carlo
    2007 Pontiac Grand PrixTechnicians should be advised that after the fuel level sensor (sender card) is replaced, the fuel gauge may read backwards. This condition may occur due to improper installation of a 2006 or prior fuel sender card into a 2007 model year vehicle.
    The resistance of the fuel level sensor for the 2007 MY is 40 ohms when the fuel tank is full and 250 ohms when the fuel tank is empty. On the 2006 MY and prior vehicles, the resistance of the fuel level sensor is 250 ohms when the fuel tank is full and 40 ohms when empty. For this reason, when replacing a fuel level sensor, the 2007 MY part number must be used for the 2007 vehicles and the 2006 MY parts must be used on the 2006 vehicles. The fuel level sensor is NOT interchangeable between model years.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  10. #10 Re: Stock 2006 GT track run
    Jan 2013
    Edmonton, Alberta
    you don't need overkill to correct the gauge reading, just some smarts. I got that from alldata as im getting rdy to drop in a 04 pcm
  1. Track times? Stock
    By mudneck4 in forum 5.3L V8 (LS4)
    Last Post: 05-06-2013, 01:00 AM
  2. Took my STOCK gtp to the track today...
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 05:03 PM
  3. stock pulley 99% of time, 3.4 for 2 track days per year?
    By hockeymaniak88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2009, 08:26 AM
