Thread: 2005 Grand Prix GTP 80-150mph
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: 2005 Grand Prix GTP 80-150mph
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Quote Originally Posted by blueguy View Post
    y u buy poopoo cam?
    Because $180 brand new and the amazing service I get with intense.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #22 Re: 2005 Grand Prix GTP 80-150mph
    Sure...but why did you buy a poopoo cam with SO many better options?
  3. #23 Re: 2005 Grand Prix GTP 80-150mph
    Apr 2012
    Middletown DE
    I set up the Aeroforce to light up with anything higher than 0.10 and I was getting knock with the 3gph nozzle, I saw .90kr at wot and anywhere between 0.2-2.0 the first second of having the gas mashed. I put the 7gph nozzle on and no knock at WOT not and the AFR is still nice 10.3-11.3 but I still get the initial KR which I only think is caused by the 1 second the meth is not getting to the engine.
    and 91parkave
    I dont believe that was done, Ill ask but I doubt it, I have been reading more and more about tuning with HPTuners so maybe by next spring I will be comfortable enough to play with it on my own..
    1993 Oldmobile 88
  4. #24 Re: 2005 Grand Prix GTP 80-150mph
    Apr 2012
    Middletown DE
    The numbers were good for what I was paying for it, I could have gone with an XP cam but, why be like everyone else? If I did another cam turbo or blower it would be a custom grind..
    1993 Oldmobile 88
  5. #25 Re: 2005 Grand Prix GTP 80-150mph
    I'm not saying "be like everyone else"...but there is a reason most people don't buy the S2X because the numbers haven't ever been that impressive.
    How about..."different isn't always better?"
    I'm not saying you made a bad choice...just...could have been better routes to take.
    Regardless, when you go to upgrade...how about just tossing rockers on it to make your life easier?
  6. #26 Re: 2005 Grand Prix GTP 80-150mph
    Apr 2012
    Middletown DE
    I don't know what your issue is with the intense blower cams but check the numbers.. the XP and this cam are damn near the same. If someone had low numbers and moved to the xp cam and saw bigger numbers, 100% its probably who ever tuned it.
    XP
    • 212°/224° at .050"
    • Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
    • Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
    • 116 Lobe Separation
      S2X
      duration @ .050": 214/222, lobe lifts: .332"/.338", valve lifts with 1.60:1 rocker arms: .531"/.541", lobe separation angle: 115, intake centerline: 111
      P.S 8k miles in and still no oil burn at all.
    1993 Oldmobile 88
  7. #27 Re: 2005 Grand Prix GTP 80-150mph
    Slower, Lower Delaware
    Cams are pretty similar. Acids view that tuning would make the difference could be right.
    Looks like a difference of opinion, opinion = a belief or judgment that rests on grounds insufficient to produce complete certainty.
  8. #28 Re: 2005 Grand Prix GTP 80-150mph
    Apr 2012
    Middletown DE
    Quote Originally Posted by Sudden View Post
    Truly the only advantage is the XP cam would give just a little bit more power through the entire power band than the s2x which really doesn't pick up until the end of it which I have experienced real world.. That car loves to go over 100mph
    1993 Oldmobile 88
  9. #29 Re: 2005 Grand Prix GTP 80-150mph
    lol, I have no issue with IS based cams broham.
    Just from what I've PERSONALLY seen, they haven't been a popular choice.
    If it works for you then more power to ya.
    Not trying to get you all bent out of shape there killer.
  1. 2005 grand prix gtp
    By plummer 29 in forum General Grand Prix Discussion
    Last Post: 04-20-2012, 07:15 AM
  2. 2005 Grand Prix
    By 2005GrandPrix in forum Members Rides
    Last Post: 06-15-2011, 04:28 PM
  3. My New 2005 Grand Prix
    By extreme in forum 04+ Specifics
    Last Post: 08-10-2009, 10:18 AM
