Thread: 1/4 Mile Results are in(no traction :-/ )**(redemption run June 21st)**
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 41 to 60 of 116
  1. #41 Re: 1/4 Mile Results are in(no traction :-/ )
    SWPA
    Quote Originally Posted by mechguy View Post
    I think what you may be trying to say is that a lower ET could have a lower trap speed than a higher ET. Which is obvious. But according to your other post, "getting off the line faster could result in trap speed going down" isn't valid. That's incorrect because all things being equal, a better launch would have to equate to a faster trap speed, otherwise the car would have started slowing down. LOL.
    Wrong.
    Getting off the line with less wheel spin will bring trap speeds DOWN, but also equate into lower ET's. With wheel spin you're going to have a higher trap but not go as far as quick.
  2. #42 Re: 1/4 Mile Results are in(no traction :-/ )
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Pass A: Spins its tires excessively. Using arbitrary numbers, the car passes 500 feet at 60 MPH and no longer has enough power to spin its tires.
    Pass B: Less wheelspin results in a better launch. The car passes the 500 foot mark at 70MPH. Clearly this pass will result in a faster trap speed because the car is moving faster at the same distance.
    Your logic is the opposite. Please explain where I am wrong.
  3. #43 Re: 1/4 Mile Results are in(no traction :-/ )
    new britain, ct
    spinnin aint winnin.
    that simple
    07 Black GXP.
  4. #44 Re: 1/4 Mile Results are in(no traction :-/ )
    SWPA
    Your scenario doesn't work. When spinning your RPMs are up. Higher RPMs equals more MPH. If I had more time I could try to explain it yet again.
    Just quickly, higher rpms equals higher in power band at a shorter point on the track equals more mph at end of track. SIMPLE
  5. #45 Re: 1/4 Mile Results are in(no traction :-/ )
    Dec 2010
    Canada
    You're saying that the most spinning is the fastest trap speed. Spinning isn't putting power to the ground.
    One possible reason you can't understand is that different cars have different power & torque curves and different traction characteristics.
    Edit: Forgot to mention that ultimately, trap speed is inversely proportional with ET.
    Relation between ET and trap speed in drag racing
  6. #46 Re: 1/4 Mile Results are in(no traction :-/ )
    SE Level Member Reverant GTP's Avatar
    Iowa
    Most of the time if you 60ft better you will trap lower... the exact reasoning behind this I don't think anyone truly knows... its just how it is. Fwd cars tend to have high traps cuz they can't hook, awd cars have low trap speeds cuz they hook but lower et's... rwd it all depends on set up. Its just how it is. Think of it as if you cross the line sooner you have less chance to build up speed.
  7. #47 Re: 1/4 Mile Results are in(no traction :-/ )
    Iowa
    If you go to the track often and watch other cars you can plainly see it happen all the time. On street tires I will trap 109-111 but on drag radials trap 107-109. I would say this mostly applies to the average street car at the track. The full drag cars with countless hours in suspension and power to run single digits is a whole new ball game and shouldn't be compared to your 11 an under cars.
  8. #48 Re: 1/4 Mile Results are in(no traction :-/ )
    Cambridge, Ontario Canada
    GTP's don't make much high end RPM HP - higher RPM only equals higher MPH with traction but I think you are kinda on the right track imo anyway...
    My take is that when spinning or losing traction, which sometimes results in higher trap speeds, is due to of all the energy in a spinning tire that eventually hooks & allows a car to avoid a portion of slower acceleration with perfect grip. Your ET goes to poop but you ended up hooking at a slightly higher speed which is turns allows you to hit a higher speed by the time you get to the last 60 feet of the track (where many 1/4 miles measure trap speed - avg over last 60 ft). There are also a million other factors that come into play as no run is exactly the same as another. I have actually had runs where ET & MPH were the best of the night in a single drag, even over 15 passes in a night.
    2005 E55 - stock
  9. #49 Re: 1/4 Mile Results are in(no traction :-/ )
    Is this really a debate?
  10. #50 Re: 1/4 Mile Results are in(no traction :-/ )
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    Quote Originally Posted by blueguy View Post
    Apparently, yes.
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  11. #51 Re: 1/4 Mile Results are in(no traction :-/ )
    Iowa
    A debate against people who go to the track n race and those who don't apparently.
  12. #52 Re: 1/4 Mile Results are in(no traction :-/ )
    May 2011
    Kansas city
    Quote Originally Posted by Reverant GTP View Post
    Pretty much what I thought too.
  13. #53 Re: 1/4 Mile Results are in(no traction :-/ )
    SWPA
    You're still not getting it.
    I know from experiece and pure physics explains why I am correct. You are correct in saying that spinning isn't putting the power to the ground, but spinning is getting RPMs up faster. Higher RPM's equals higher MPH.
  14. #54 Re: 1/4 Mile Results are in(no traction :-/ )
    Texas
    Why is it difficult to understand that when you spin the wheels its like you are starting at a X mph at the beginning of the dragstrip?
    85 Corvette
    01 TA
    03 Z06
  15. #55 Re: 1/4 Mile Results are in(no traction :-/ )
    Dec 2010
    Canada
    I only practice physics, not taboo theories, so it seems we will not be in agreement.
  16. #56 Re: 1/4 Mile Results are in(no traction :-/ )
    SWPA
    Its not a theory. Physics proves my point to be correct.
  17. #57 Re: 1/4 Mile Results are in(no traction :-/ )
    mi
    higher elapsed time gives you more time to accelerate so your mph will be higher
  18. #58 Re: 1/4 Mile Results are in(no traction :-/ )
    Dec 2010
    Canada
    "Higher RPM = higher MPH" isn't even close to a physical concept, its a trollilololololipop. Why don't you have scientific proof of your theories? Maybe you meant higher HP = higher MPH?
  19. #59 Re: 1/4 Mile Results are in(no traction :-/ )
    SWPA
    True or false 5000 rpm in 3rd gear is a faster mph than 4500 rpm in 3rd gear?
    There is no theory there. There is fact.
  20. #60 Re: 1/4 Mile Results are in(no traction :-/ )
    Dec 2010
    Canada
    True or false:
    4 doors are 2 more doors than 2 doors.
  1. Replies: 2
    Last Post: 02-14-2012, 08:47 PM
  2. 1/4 Mile
    By zildjian102 in forum Off Topic Discussion
    Last Post: 04-16-2011, 07:43 AM
  3. 77k mile l67 ???
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-28-2010, 07:03 PM
  4. help makin a sig
    By GrandPrixGT00 in forum Off Topic Discussion
    Last Post: 07-22-2009, 11:14 AM
  5. Tranny makin noises, rebuilt 30k ago
    By minichopper6hp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2009, 03:37 PM
