Thread: Today at the track(05GXP)
Results 1 to 20 of 23
  1. #1 Today at the track(05GXP)
    SE Level Member gagt3100's Avatar
    Mar 2012
    Milwaukee, Wisconsin, United States
    So I decided to take my 05 gxp with 98k miles on it to the track.
    All it has is a CAI.
    Ran a 14.337, 14.335, and 14.556
    I held second gear til the end, TC off.
    Am I missing something? I thought our cars were suppose to run 14.2 stock?
  2. #2 Re: Today at the track(05GXP)
    Tires (and pressure), air temp, track prep all come into play.
    Your car also has 98k miles, its not exactly new, so your times seem alright.
  3. #3 Re: Today at the track(05GXP)
    Jun 2011
    Lots of variables.
    Just be glad its in the 14s.
  4. #4 Re: Today at the track(05GXP)
    Mar 2012
    Track temp was 90, air temp was 81, Tire pressure was 40ish, track had glue I had a little tire spin not much just hammering on the light, I have a video let me try to get a link for you guys
  5. #5 Re: Today at the track(05GXP)
    30 psi would have been better, but I bet on a cooler night the car would pick up a tenth or two.
    And maybe some 93 octane or race gas.
  6. #6 Re: Today at the track(05GXP)
    GTX Level Member crbquist's Avatar
    Massachusetts
    Crazy how you can throw a cam and a smaller pulley on a 3800 and usually run a faster time. Decent times for a gxp though
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  7. #7 Re: Today at the track(05GXP)
    Mar 2012
    I had 93 octane too with less than 1/4th of a tank for less weight lol
  8. #8 Re: Today at the track(05GXP)
    Mar 2012
    Quote Originally Posted by crbquist View Post
    I know!!! I went up against a gtp with a smaller pully, DP, and a tune and he pulled on me, but not by much.
  9. #9 Re: Today at the track(05GXP)
    Mar 2012
  10. #10 Re: Today at the track(05GXP)
    Mar 2012
  11. #11 Re: Today at the track(05GXP)
    Lower the tire pressure to the mid to high 20's...
    Remove the junk in the trunk if you didn't...jack, spare tire, etc.
    Remove the headlight so you get more air in there...
    Drive around the water box (don't do a burnout either...and "barking the tires to clean them off is hard on the input shafts...which these cars have a weak transmission anyways...)
    Flip that dog bone mount if you haven't done it....better power transfer to the ground...less play under load (you can find how to do that if you haven't in my safely modding thread, as they are the same on a 3800).
    Also, leave it in drive and try again Those cars also seem to gain some alright power from a cutout as well...I wouldn't do a electric one, just have a "Y" welded in before the cat and a 3 bolt flange put on there and undo it when you get to the track.
    Lower side of 14's aren't that bad. Gotta remember it's a big FWD family sedan.
  12. #12 Re: Today at the track(05GXP)
    Mar 2012
    Thank you bluegtp91, trunk was empty but the tire/jack was still in there, I kept it in drive from 1st to 2nd then went to tap shift and held 2nd. I also drove around the waterbox. I may look into a cutout aswell for a few extra ponies and Ill try removing my headlight by the intake next time. Thanks for your tips!! I also read your motor mount flip and I may try that, if I do I will let you know.
  13. #13 Re: Today at the track(05GXP)
    TAPshift actually has been proven to slow the car down.
    Either hold it in 2 until it hits redline and upshift to drive or leave it alone in drive. It's an automatic...that's what it does...shift for you so you don't kill the thing like using TAPshift
  14. #14 Re: Today at the track(05GXP)
    Mar 2012
    yeah I know I just put it in tap shift about 1/2 way down after it auto shifted into second just so it would not shift into third at the light and loose a few MPH
  15. #15 Re: Today at the track(05GXP)
    Omaha, NE
    You should get a tuner so you can adjust for density altitude.
  16. #16 Re: Today at the track(05GXP)
    Apr 2009
    Fort Worth TX
    A good upgrade may be a Transgo shift kit. For the GTP it's cheap, easy to install, and very effective. I don't know about the GXP though.
  17. #17 Re: Today at the track(05GXP)
    Quote Originally Posted by Rico View Post
    It's the same transmission, I'd rather get an Intense Kit and replace all the mounts at the same time since I'm sure they are toast as well after some abuse.
  18. #18 Re: Today at the track(05GXP)
    Oct 2011
    Puyallup WA
    Get that GXP tuned the stock tune is crazy weird doesn't go into to PE till like almost redline...my friend tuned his brothers GXP and the stock tune had alot of TM combined with the weird PE and hella rich AF...just tuning really woke up that LS motor that would be first on my list personally...just my 2 cents
    08 G8 GT - exhaust Tune
  19. #19 Re: Today at the track(05GXP)
    Yoga city
    what did your trans temps hit?
  20. #20 Re: Today at the track(05GXP)
    Mar 2012
    Thanks all for the responces, I will look into a tune. I just dont know who or where around here where I live(milwaukee) there would be a one?
    Quote Originally Posted by Jteske88 View Post
    Temp hit 220 after about 4 hot laps then I shut it down. The motor kept getting hot aswell on the return lane. I am looking into a thermostat 160 or 180? Aswell as hardwiring the fans to a switch.
  1. Went to the track Today
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 07-31-2011, 09:30 PM
  2. WOT/ track vid.
    By glanzergtx in forum Track Sessions and Kills
    Last Post: 06-30-2011, 01:41 PM
  3. Track day
    By Whitehispanic in forum Track Sessions and Kills
    Last Post: 10-06-2010, 07:35 PM
  4. Took my STOCK gtp to the track today...
    By Mikegotone'02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2009, 05:03 PM
  5. So I went to the track right?
    By TDCRacing in forum Off Topic Discussion
    Last Post: 04-05-2008, 11:57 AM
