Thread: My daytona vs late 90's f150
Results 1 to 20 of 34
  1. #1 My daytona vs late 90's f150
    Sep 2011
    South Central PA
    Was in town last night when a red late 90's f150 regular cab comes flying past me. The light turns red and we are first in line, him in one lane me in the other. I look over at him and see he is like mid 40's or so. He looked back at me. I didnt even think anything of racing just because he was older I just thought he had somewere to go or something. Light turns green and he takes off. I drove as normal not racing. I hear him chirp 2nd gear and thats when Im like its on. I didnt even hit the preformance shift button I just went. By this point he was a car and a half in front of me. I caught up to him and passed him like he was standing still. Not that my car is fast by any means. In fact its not running 100%. It sputters at high rpm. Scangauge is on its way to my house. Also replaced the high speed fuel pump relay and its still acting up. Anyway after I passed him he tried to change lanes and everything to catch up to me. At this point I slowed down because we were in downtown and thats not the smartest thing to do. Anyway a kill is a kill and its always fun to show someone that the gtp is no slouch
    2000 Grand Prix GTP Daytona 500
    WBS PCM, 3.5 Pulley, 3'' DP into Magnaflow Hi Flow Cat, Powerlog, No resonator, Wizaraid Intake, ZZP Wires, AL 104's, 180 Stat, Poly Dogbone Bushings, Optima Yellow top battery
  2. #2 Re: My daytona vs late 90's f150
    utah
    so your beating on it...but its not running right? knock knock...whos there? boom
  3. #3 Re: My daytona vs late 90's f150
    GTP Level Member mrlogic1234's Avatar
    Jul 2010
    Detroit
    Yea man thats not smart at all... Why even waste your gas on a F-150 anyway? Lightning maybe, but otherwise its a waste of time.
    Ryan
    2000 GTP Coupe Green/Grey - SOLD!
    2008 GXP Black/Ebony
  4. #4 Re: My daytona vs late 90's f150
    Mullet Member Wotgtp's Avatar
    Connecticut
    Hello fellow daytona owner. Nice kill, but hookup the scangauge before the next run imo you might have some knock or ignition issues.
  5. #5 Re: My daytona vs late 90's f150
    Sep 2011
    South Central PA
    I did a first gear run. As soon as it was about to shift into 2nd I shut it down. Yes I shouldnt have even been doing it but I felt the need to do it for some reason. Which specifics should I be looking for with my scangauge?
  6. #6 Re: My daytona vs late 90's f150
    utah
    Knock knock
    Ohio
    Who's there?
    Sent from my DROIDX using Tapatalk
  8. #8 Re: My daytona vs late 90's f150
    utah
    Knock!
  9. #9 Re: My daytona vs late 90's f150
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Quote Originally Posted by boostedcompg View Post
    Knock knock
    Quote Originally Posted by 99pgpgt View Post
    Who's there?
    Knock!
    Shouldn't it be "boom" at the door?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  10. #10 Re: My daytona vs late 90's f150
    Texas
    Quote Originally Posted by thatguy View Post
    What is the car doing that makes it feel like it's running bad?
    Also is it the scangauge II? I actually just picked one up. I really like how it displays 4 things at once.
    You can't scan for knock. Gauges don't do that. They scan for KR which is knock retard. So the jokes they were making actually were pretty stupid and made them look fairly ignorant. The only one worth laughing at was the boom one I chuckled cause it actually made sense.
    Some things I suggest you to scan for:
    KR-obviously 0 so no timing is being pulled
    LTFT-long term fuel trims. You want them locked at 0
    Ignition timing- you have an aftermarket PCM so I would be curious what they set it at.
    O2's volts- this will you give you some idea if you are running rich or lean
    RPM- because you want to know where exactly it's acting up
    MAF- I doubt you are maxing the MAF but it's always good to check(11,000 htz is max)
    Injector duty cycle- you probably aren't maxing them, but check it anyways.
    That should get you started. From there I would suggest searching on MULTIPLE GP sites.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: My daytona vs late 90's f150
    Sep 2011
    South Central PA
    Alright. I ignore the jokes. Thank you for actually helping me out. I will look into the specifics and I will pm you my results. Its the aeroforce interceptor scan gauge. I know timing was set at 4 degrees above stock. I simply do not understand it, I have another thread open about my sputtering problems. Basically I had a bad injector, got that fixed, then the fuel pump resistor went out so I had that fixed and now its acting up. Only at like 5k rpm it sputters. It ran amazing before the injector went out so all these jokes about knock should not even affect it because it was running fine before hand. Its gotta be something with fuel but I have no idea
  12. #12 Re: My daytona vs late 90's f150
    utah
    He's a smartbro....not a madbro
    Ohio
    The jokes weren't about rod knock... They were about kr, somebody can't understand I guess? Noah, we're idiots
  14. #14 Re: My daytona vs late 90's f150
    The dark side of the Moon
    Quote Originally Posted by mrlogic1234 View Post
    Lulz, most of you guys don't have any business messin round with lightings.
  15. #15 Re: My daytona vs late 90's f150
    Ohio
    i rape them on a daily...get at me?
  16. #16 Re: My daytona vs late 90's f150
    I'm already at you.
  17. #17 Re: My daytona vs late 90's f150
    Ohio
    I'm already at you.
    get at me again lol
  18. #18 Re: My daytona vs late 90's f150
    lighting is dangerous stuff.
  19. #19 Re: My daytona vs late 90's f150
    I'll run a 95 and down lightning any day lol
  20. #20 Re: My daytona vs late 90's f150
    Sep 2011
    South Central PA
    The jokes weren't about rod knock... They were about kr, somebody can't understand I guess? Noah, we're idiots Sent from my DROIDX using Tapatalk
    Who ever said you were idiots? I know you are talking about KR. What I said is I don't understand how it would suddenly happen when it hasn't before. All that happened was 2 defective parts were replaced. I didnt have this issue before. Thats all I am saying. Not trying to fight or anything. Thats why I am on this site, is to get help, to get opinions, to learn and to understand about this platform. I have only been a grand prix owner since october so I do not know anything about these cars. Thats why I ask for help. Thank you to the guys who are pointing me in the right direction. I appreciate it
  1. Wow, I'm late....
    By Fatboy501 in forum Introductions/Noob Questions
    Last Post: 09-21-2011, 02:00 AM
  2. modded f150
    By Rather B Blown in forum Track Sessions and Kills
    Last Post: 01-16-2010, 08:19 PM
  3. F150 + Regal + Ram
    By Toofastgs in forum Track Sessions and Kills
    Last Post: 08-28-2008, 05:11 AM
