Thread: Went to the track Friday...
Results 1 to 17 of 17
  1. #1 Went to the track Friday...
    SE Level Member ls1freek's Avatar
    Sublette, Ks
    Completely stock:
    15.0@91
    Is that good? The density altitude was around +3500 feet. I was feathering the throttle till about 10-15 mph because stock tires and boost = no traction lol.
    2005 Grand Prix GTP w/CompG
    - Stock
  2. #2 Re: Went to the track Friday...
    Donating User Odi's Avatar
    Chicago South Suburbs
    on stocks and completely stock i say you did good. depending on how good your tires are, with a lil bit of practice u should hit 14.9's and 14.8's.
    do yourself a favor and make yourself a intake for more whine.
  3. #3 Re: Went to the track Friday...
  4. #4 Re: Went to the track Friday...
    Sublette, Ks
    My best was a 2.2x (I don't have the slips at the moment) but it was on a different run, 15.1@90, on the best run it was a 2.34 I believe...
    - Stock
  5. #5 Re: Went to the track Friday...
    need a lower 60 for sure.
    (tires and driver mod)
  6. #6 Re: Went to the track Friday...
    Sublette, Ks
    Driver mod is there lol its the tires! I've been drag racing for over 10 years. The best 60 foot was when I brake stalled it to 2500 off the line and worked the pedal down to the floor by the time I hit 10 mph, all with no tire spin. If I tried ANY other way, it was either tire spin and/or a slower 60'. It just needs slicks and a tune, then mid 14's are easily achieved. Also, my buddy owns HP Tuners, he looked at the stock tune and told me the factory torque management settings limits the calculated engine torque to, if I can recall correctly, 150 foot pounds of torque all the way through 1st gear. In that case, a tune and slicks should drastically improve my 60'.
    - Stock
  7. #7 Re: Went to the track Friday...
    do NOT delete torque management.
    Just manipulate it for more fun.
  8. #8 Re: Went to the track Friday...
    Sublette, Ks
    Lol, yeah I've heard these trannys don't like all the TM removed...
    - Stock
  9. #9 Re: Went to the track Friday...
    It helps them shift.
  10. #10 Re: Went to the track Friday...
    Jersey
    i have my torque reduction 0'ed out
    after the new build tho, i gotta put some back
    16' wrx sti- stock
  11. #11 Re: Went to the track Friday...
    Portland Oregon
    Best I did with my compg stock was a 14.5 with a density altitude at negative sealevel. Portland international raceway is at sea level
  12. #12 Re: Went to the track Friday...
    Bone stock supercharged '07 car here went almost 14.8 with a 2.1 60 foot. DBW cars are a little trickier to launch I've found out...and way touchier than cable driven TB cars. I'd be willing to bet you could knock a few tenths off that time with a better 60 foot...and the headlight/air filter yanked out
  13. #13 Re: Went to the track Friday...
    Sublette, Ks
    I'm gonna try to make it out to the track again this Friday night, go for a 14.x!
    - Stock
  14. #14 Re: Went to the track Friday...
    GTP Level Member
    Nov 2008
    MA
    instead of stalling at 2500 then feathering the throttle, launch at 1500-1800 then you will launch quicker.easier and have less throttle feathering to do..if that makes sense
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  15. #15 Re: Went to the track Friday...
    Panama City Beach, FL
    Or, hang around here and learn how to E-Whine.
  16. #16 Re: Went to the track Friday...
    Quote Originally Posted by 02 WS6 TA View Post
    Yay, fun yob.
  17. #17 Re: Went to the track Friday...
    Worthless Troll
    I'd say that's damn good considering the DA. At sea level that would have probably been mid 14's easy @ 94-95mph.
  1. BlackOUT friday
    By GAFF in forum Off Topic Discussion
    Last Post: 11-29-2010, 10:25 PM
  2. Black Friday
    By KawaFord in forum Off Topic Discussion
    Last Post: 11-28-2010, 05:44 PM
  3. i had a fun friday night :D
    By Dragonblaze in forum Off Topic Discussion
    Last Post: 09-30-2010, 05:59 PM
  4. Black Friday
    By UR LOSN in forum Off Topic Discussion
    Last Post: 12-01-2008, 12:43 AM
  5. Interesting Black friday
    By Toofastgs in forum Off Topic Discussion
    Last Post: 11-29-2008, 07:11 PM
