Thread: 02 GP GT vs 08 Caddie CTS
Results 1 to 15 of 15
  1. #1 02 GP GT vs 08 Caddie CTS
    Apr 2009
    Wausau, Wisconsin
    Pulled a CTS like a week or two ago. It was an old friend of mine (friendship ended on bad terms) and he flew past me so i stepped on it and started to pull ahead. Then came up to a red light. Light turned green and I noticed I forgot to turn off Traction Control so he gets the jump as I shift up then back down. As soon as he hits 2nd I blow past him then he turned off.
    Any advice for the shifting?
  2. #2 Re: 02 GP GT vs 08 Caddie CTS
    Yeah, if you like your transmission IN your car quit manually shifting it up and down. Leave it in Drive and turn TCS off. Then get some mods.
  3. #3 Re: 02 GP GT vs 08 Caddie CTS
    Donating Users blowfishRus6's Avatar
    g.a.
    good thing it wasent a cts-v. corvette motor with 6 speeds
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  4. #4 Re: 02 GP GT vs 08 Caddie CTS
    LS9 FTW!! lol
  5. #5 Re: 02 GP GT vs 08 Caddie CTS
    Donating Users
    Plainfield, IL
    Quote Originally Posted by blowfishRus6 View Post
    the new cts-v is even worse lemme look it up....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  6. #6 Re: 02 GP GT vs 08 Caddie CTS
    Donating Users
    Plainfield, IL
    LS9 FTW!! lol
    the new cts-v has a eaton TVS twinscrewed LSA motor he would have got butt raped....556 crank horsepower with a 6 speed..and just to make it worse it comes intercooled from the factory
    2009 cts-v
  7. #7 Re: 02 GP GT vs 08 Caddie CTS
    Barksdale AFB, LA
    LS9 FTW!! lol
    It's not the LS9. It's the LSA. There's quite a few things different. The LSA has more in common with the LS3 than the LS9.
    2009 Subaru Impreza WRX STI
  8. #8 Re: 02 GP GT vs 08 Caddie CTS
    Well it is basically the design of the LS9 with many different characteristics...it is still all aluminum 6.2 with the Eaton Blower...granted the Vette has a 2.3 vs. the Caddy's 1.9 or something like that. Boost is lower on the Caddy...its under 10psi. Intercooled differently...pistons arent forged...ummm...oh and the Caddy has a 3 belt system vs. the ZR1's typical twin belt setup like on a GTP for instance...miss anything?
  9. #9 Re: 02 GP GT vs 08 Caddie CTS
    Barksdale AFB, LA
    LS9 has titanium components in the valve train and different block characteristics around the cylinder walls as well as a dry sump oil system. The LSA has no titanium, same block as the LS3, and a wet sump.
    It's pretty much an LS3 with the LS9's blower.
  10. #10 Re: 02 GP GT vs 08 Caddie CTS
    The TVS blower is different though on the LS9 and the LSA. The ZR1's is bigger by nearly a half of a liter of displacement.
  11. #11 Re: 02 GP GT vs 08 Caddie CTS
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Even the V6 ones make 304HP.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  12. #12 Re: 02 GP GT vs 08 Caddie CTS
    GT Level Member silvermistchick's Avatar
    Jan 2009
    Atlanta, GA
    must have been a regular 3.6 because the di3.6 is 306 hp and will own a n/a3.8. even though it weighs 3900lbs. but i did beatup on an 03 3.2 cts but its plugs were fouled out and had oil in the plug holes
  13. #13 Re: 02 GP GT vs 08 Caddie CTS
    Barksdale AFB, LA
    Ah yes you're right. Just adds to it that it has little to do with the LS9.
  14. #14 Re: 02 GP GT vs 08 Caddie CTS
    g.a.
    its slow.
  15. #15 Re: 02 GP GT vs 08 Caddie CTS
    Donating Users
    Plainfield, IL
