Thread: Dynoing my gtp
Results 1 to 10 of 10
  1. #1 Dynoing my gtp
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I'll be going to zzp on the 29th to see what kind of power my gtp makes. I'd like to break the nic cam record but I'm not holding my breath. I've done a lot more tuning on it and it's at a "safe" 2.7 pulley, 26* timing, 11.6 Afr. Hopefully it doesn't pop on the dyno.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Dynoing my gtp
    I break stuff selliott's Avatar
    Kansas City
    Go baby go!
  3. #3 Re: Dynoing my gtp
    May 2008
    Schuyler, NE
    Lol. Safe and 26° of timing don't belong in the same sentence.
  4. Likes Pursell1911 liked this post
  5. #4 Re: Dynoing my gtp
    Apr 2014
    South Haven, MI
    That's why it's in quotes lol
  6. #5 Re: Dynoing my gtp
    Apr 2014
    South Haven, MI
    I'd like to think I'd be around 350 whp with my current mods.
    E85, stage 3 heads, nic, pacesetters, 26* timing, 11.6 Afr, Gen v (2.7 pulley, n*, Lq4 maf, etc
    I'm near out flowing my 60# injectors and Lq4 maf. I've seen 113xx on the maf (401 GPS) if that helps with any calculations.
  7. #6 Re: Dynoing my gtp
    May 2008
    Schuyler, NE
    You're definitely making decent power. 60lb injectors max around 500chp on e85, so make sure you don't have any other issues with your fuel system.
  8. #7 Re: Dynoing my gtp
    you just might want to creep up on that 26º wot. 21 -22 is about all you need really. seems theres no returns running any higher. so ive heard anyways. i cant get mine up there thats for sure lol
  9. #8 Re: Dynoing my gtp
    Apr 2014
    South Haven, MI
    I thought that too. I just decided to increase the timing because I couldn't drop lower than a 2.5. I've seen people lose horsepower by going that low so I pulleyd up to the 2.7 and slowly increased timing since I figured it would be better than going out of the efficiency range of the m90 (also adding a lot of heat). Each degree seemed to help a little until I hit 27-28*. At that point I got .5*-1* of kr so I backed it down. All of the tuning was done on a 85* day.
  10. #9 Re: Dynoing my gtp
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    You'll hit 340, maybe 350 to the wheels. I hit 325 with 19 degrees timing e85, s1x, 2.8 setup. And i was getting knock up top (1-2 degrees).
    You got a good setup. post vids.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  11. #10 Re: Dynoing my gtp
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    So.... What do you get??????
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. Regal Dynoing on 1320
    By radiocrash in forum Off Topic Discussion
    Last Post: 03-21-2013, 11:15 AM
