Thread: race sat at mason and dixon
Results 1 to 20 of 30
  1. #1 race sat at mason and dixon
    Mar 2017
    West Virginia
    raced sat very bad the was good in 60' 2.19 but very from 15.30 to 16.70
    mph 80 to 89
    weather was 2200' da 70 deg and a head wind but why did it very
  2. #2 Re: race sat at mason and dixon
    did you spin the tires at all on the runs? if you let off it shifts to second and dogs, and theres the time gone. been there.
  3. #3 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    no tire spin
    on 2 runs it left and then boog which i do not think can happen
    temp of engine was always above 185
  4. #4 Re: race sat at mason and dixon
    you tuned? got mods?
  5. #5 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    only thing done is a k and n filter
    2005 pontiac gtp
  6. #6 Re: race sat at mason and dixon
    Still seems like tire spin with the 60 foot and traction control/stabiltrak kicking in. Only way to completely disable the system is to pull the ABS fuse.
    A better launch with a good 60 foot should gain you back a half second. Lower tire pressure up front, run the highest grade premium you have around, remove any random weight.
  7. #7 Re: race sat at mason and dixon
    sounds about right especially the DA (according to dragtimes the DA was ~1450 feet) and a headwind on a basically stock L32 with a 2.15-2.20 sixty footer. if the runs where he was in the 16s that his sixty footers were higher than 2.19 that would explain the lower end trap speeds.
  8. #8 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    had the ABS turn off nest i will remove the fuse
  9. #9 Re: race sat at mason and dixon
    sounds like stock times really. hell im still trying to get past a 14.1, im my defense it was spinning.
  10. #10 Re: race sat at mason and dixon
    Sep 2017
    New Mexico
    I had similar results a couple months ago. Ran a 15.6@87 with 2.3 60ft. I didn't hear it feel tire spin and my buddy looking from the stands said the same thing. Mods were just come filter, headers with cattless downpipe.
  11. #11 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    there is something going on in the computer in my case
    i know it did not spin the tires
  12. #12 Re: race sat at mason and dixon
    Without a log file of the run you'll never know.
    Though I still think it has nothing to do with the computer at all. With the ABS fuse pulled, traction control disabled the computer is not just going to yank power away and make it slower. It's not even making enough power to put it in an abuse mode or limp mode situation and retard the power.
    Keep in mind with a perfect launch and perfect weather conditions the car is likely to only run a 14.5-15.0 quarter mile time. Any hesitation off the line or any slow launch/wheel spin will take many tenths off your time.
    If you don't drag race it every weekend it's hard to get a rhythm down to get the best results.
  13. #13 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    ok
    but 60' was from 2.19 to 2.5
    that not 15.3 to 16.7
    spin does not take away 9mph
    from 1000' to 1320 i lose .3
    that is not spin
    it is not missing
  14. #14 Re: race sat at mason and dixon
    vicg, how did you accelerate off the line? did you:
    1-brake torqued it close to converter limit
    2-gradually eased into the throttle
    3-aggressively planted the pedal to the metal?
    also any idea on what tire pressure did you run on all of the runs? did you even touch the tire pressure and if not, what pressure do you usually run it at?
  15. #15 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    start line 1800
    25# pressure all runs
    i also lose .27 660 to 1000
  16. #16 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    over the winter i am going to remove the cat., and res.,
    i hope to get somebody to put a program in the car
    BUT
    the race car comes first which i am freshening up now
  17. #17 Re: race sat at mason and dixon
    I see the cat removal and resonator removal making no difference. For sure the resonator, it more than big enough to flow enough gases through it. Stock exhaust sizing isn't an issue until well over 300whp. You're car maybe makes 220whp give or take.
  18. #18 Re: race sat at mason and dixon
    Mar 2017
    West Virginia
    maybe 200hp
    i did run the car at a NHRA race in stock it weight 3830
  19. #19 Re: race sat at mason and dixon
    Sep 2015
    Cheyenne, WY
    Quote Originally Posted by vicg View Post
    These cars weigh under 3500 lbs.
    Why a 300+ lb difference?
    2007 Antique Bronze Metalic Grand Prix GT...bone stock.
  20. #20 Re: race sat at mason and dixon
    Sep 2015
    Cheyenne, WY
    I'm also confused as to how you lost so much ET.
    In your thread asking about headers you said,
    "i have ran 14.31 at 92 on a 14.85 index..."
  1. mason and dixon dragway
    By vicg in forum Track Sessions and Kills
    Last Post: 04-08-2017, 07:47 PM
  2. Well.... maybe not a race.
    By MM06GT in forum Track Sessions and Kills
    Last Post: 10-06-2016, 03:07 AM
  3. anyone race
    By BlackGT97 in forum Off Topic Discussion
    Last Post: 08-18-2011, 01:10 AM
  4. Mason Dixon Saturday 11/13/10
    By 01gpgt01 in forum Northeast
    Last Post: 11-13-2010, 06:30 AM
  5. 2 Race cars drag race
    By KawaFord in forum Off Topic Discussion
    Last Post: 09-06-2009, 02:11 AM
