Thread: new coilovers and tire size?
Results 1 to 2 of 2
  1. #1 new coilovers and tire size?
    Sep 2014
    roane county west virginia
    Im wanting to get new racing coilovers and was wondering if I did this could I also put a 18" rim on without it rubbing, also what tire size should I get?
  2. #2 Re: new coilovers and tire size?
    It may rub, it may not.
    That completey and 100% depends on wheel offset and what tire size you want to run. The lower the offset, the better chance at rubbing. If you are going to run a 18in rim, you want to stick with the tire size of 245/45/18 to keep the roughly the same rolling diameter as stock to keep the speedo in check. You cold go shorter in sidewall but then it will look stupid.
  1. Need Tire Size Help
    By nickmk06 in forum Tires & Wheels
    Last Post: 05-05-2013, 11:37 PM
  2. Tire Size
    By jamster00 in forum Tires & Wheels
    Last Post: 12-13-2011, 01:29 AM
  3. Tire size 235/55?
    By RedLedbetter in forum Tires & Wheels
    Last Post: 05-09-2009, 02:14 PM
  4. What size of tire do i need?
    By cboth686 in forum Tires & Wheels
    Last Post: 04-03-2009, 07:17 PM
  5. tire size
    By dwm1975 in forum Tires & Wheels
    Last Post: 07-24-2008, 01:03 PM
