Hey all,
A buddy of mine has a set of 4 rims he isn't using. I little bit of oxidation but otherwise in great condition. I guess they were factory Bonneville rims, but, I'm not really sure. Photo:
Hey all,
those arent 18s
^^ What they said. It is indeed off a Bonneville, and they are 17s. The only stock 18s on a Bonneville were the GXP wheels.
http://www.autopartsfair.com/pontiac...y06549u85.html
As to value, unfortunately, they are not one of the more desirable wheels, so they won't be worth much. Someone may pick them up for winter beaters, or a cheap upgrade in size/style for a GM that came with even less desirable wheels. If he could get $200-$250 for the set, I'd take it and run.
The most desirable bonneville wheels are the 18" gxp wheels.
But if you are a bonneville guy those are the second most desirable wheel. If the chrome is in good condition. Chrome starts peeling in center cap area and spreads out. You can not find good ones for less than a $125 each.
FWIW you want 18" rims. I'm running 18" Lucerne Super (V8) rims. They look great etc on the Regal. Because I kept the outer diameter the same, it's minty fresh.
| « Previous Thread | Next Thread » |
