Thread: new shoes?
Results 1 to 9 of 9
  1. #1 new shoes?
    GT Level Member Dadkota's Avatar
    Feb 2014
    Rhode Island
    I'm in the market for some new shoes on my '01 GTP. I need something affordable because I'm starting college. The GTP is bronze metallic so I'm looking for dark grey or alloy (like the stock wheels). I also want a more aggressive stance like where the tires would be flush with the fenders and I'm not sure on the size for that haha. Thanks for any suggestions or opinions!
    '01 GP GTP- Intake, Plog, 3" DP and Exhaust, DHP tuned by me, GMPP sway bars, 3.5 MPS, cold plugs and tstat
    -180,000 miles and climbing
  2. #2 Re: new shoes?
    For size, it's 18's for bust.
    I'm not a wheel guy, so I can't help much.
  3. #3 Re: new shoes?
    Feb 2014
    Rhode Island
    What about like offset and such?
  4. #4 Re: new shoes?
    Ocala, FL
    Quote Originally Posted by Dadkota View Post
    http://www.grandprixforums.net/threa...stions-In-here!!
  5. #5 Re: new shoes?
    +40ish.
  6. #6 Re: new shoes?
    GTX Level Member Bakerdd's Avatar
    Raleigh, NC
    If you want flush, do a little fender work and go for 18x9 +30. Its not too aggressive and a lot of people on here have similar setups with mustang wheels. It looks good.
  7. #7 Re: new shoes?
    Apr 2012
    Goderich, Ontario
    www.tirerack.com has some good info. I run 245/45/18 tires and I think the rims are+30 or +35 offset on a stock saggy suspension with no issue or complaints.
    This pic is from a couple years ago. The white car is compleatly stock with newer OEM springs and the red car is on 235/50/18 tires and saggy old springs. Someone else will have to chime in if you want lower.
    -Paul Walker
  8. #8 Re: new shoes?
    Feb 2014
    Rhode Island
    How about a set up for 17" wheels?
  9. #9 Re: new shoes?
    stick with 18s if you want to do the summer/winter wheels setup. 17s just aren't big enough to give that punch of awesome you're looking for.
    and i'd suggest something like an 18x8.5 +35mm wheel with a 245/45R18 tire to get a little aggressive, but still stay worry free with rubbing. unless you're comfortable with rolling the fenders, then an 18x9 +30mm wheel with the same size tire would be a little more towards the look you want.
    if i were doing it again (knowing how wheels fit on this car and what i can do with fenders and alignment), i'd be going for something 18x10 +20mm or so.
  1. New Shoes (actual shoes)
    By tayl5645 in forum Off Topic Discussion
    Last Post: 02-01-2011, 07:11 PM
  2. got some new shoes!
    By joshsGT in forum Tires & Wheels
    Last Post: 04-10-2010, 09:57 AM
  3. New Shoes for the GXP
    By BryanB in forum Tires & Wheels
    Last Post: 02-15-2010, 08:00 PM
  4. What would you do in my shoes?
    By UR LOSN in forum Off Topic Discussion
    Last Post: 12-31-2009, 04:31 PM
  5. Shoes for the new GTP
    By Coogles in forum Visual/Body Modifications
    Last Post: 03-01-2008, 01:53 PM
