Thread: Wheel stud
Results 1 to 18 of 18
  1. #1 Wheel stud
    GTP Level Member Ultra440's Avatar
    Ohio
    I apparently put a lug nut on crooked and stripped out one of my studs. Never had this happen before... does the whole hub need replaced to replace the single stud?
    2003 Park Avenue Ultra- 15% tint, 12" audiobahns, dynamatted trunk and doors, tinted tails, LEDs all around, HID headlights, f body brakes, sd headers, 3.5 pulley and supporting mods
    http://www.grandprixforums.net/my-03...tml#post824292
  2. #2 Re: Wheel stud
    Should be able to just pound the stud out and pound a new one in.
  3. #3 Re: Wheel stud
    Oct 2011
    Toledo, OH
    Since you can buy single OEM studs, and longer aftermarket studs I'm willing to bet they are replaceable. But for god sake don't actually pound it in or out! The hub is held on with three bolts, you can take it off and press the the stud in and out, or if you do not have access to a press, use a large C clamp with a socket on the backside of the hub.
    7"
  4. #4 Re: Wheel stud
    They pound in and out just fine no need to remove the bearing
  5. #5 Re: Wheel stud
    Oct 2011
    Toledo, OH
    I still advise against pounding on them, in either direction but especially when putting them in. You can use the C-clamp without hub removal. At least use an open ended lugnut and just tighten it to press them in.
    7"
  6. #6 Re: Wheel stud
    you cant pound them back in, so you'll need to slide the new stud in then pull it in with a open lug nut on backwards, you may have to cut one side of the back flat part of the new stud to get it in behind the hub ring.
    it maybe be best to cut the old one short then pound it out so it comes out from behind the ring.
  7. #7 Re: Wheel stud
    Dec 2012
    troll land
    If its on the rear no need to cut it to knock it out, had to replace two on the rear when I bought the car cause some @#$/head hammered the lugs on
  8. #8 Re: Wheel stud
    Ohio
    Thanks guys. Yep, on the back.
  9. #9 Re: Wheel stud
    true that, much more room on a rear hub. fronts are a tight fit tho.
  10. #10 Re: Wheel stud
    Oct 2014
    Canada
    was anyone able to get a front stud in on an 07 grand prix without removing the hub? if so please advise,thanks
  11. #11 Re: Wheel stud
    Quote Originally Posted by chuckfromcanada View Post
    yup,
  12. #12 Re: Wheel stud
    Oct 2014
    Canada
    Wheel I got the broken one off no problem but the replacement wont clear the hole to get a nut on it..i have it positioned to the right of the strut , where did you line up yours? Was the stud as long as the others?
  13. #13 Re: Wheel stud
    best spot to re install is where the caliper was. caliper, bracket and rotor need to come off.
    if you cant get the stud to go in clear. you cut one side of the backing part of the stud off. it should clear and slide in the hole.
  14. #14 Re: Wheel stud
    Oct 2014
    Canada
    Geez what a rotten job cant get it lined up anywhere 2 days on a wheel for a brake change is a joke, broken studs rusted on rotors ...
  15. #15 Re: Wheel stud
    you can always take the hub off and pound the stud in.
  16. #16 Re: Wheel stud
    Oct 2014
    Canada
    with the amount of rust on the shaft I don't see it being a good idea...lol thanks for the help
  17. #17 Re: Wheel stud
    you put the spare tire on, then lower it to the ground, then take the axle nut off with a breaker bar and a pipe. that nut will come off. theres 2 size nuts, 34 and 36 mm 36 socket will work on a 34 mm nut. ive done it.
    sooner or later it will need to come off anyways, cause that hub or axle will fail one day.
  18. #18 Re: Wheel stud
    Oct 2014
    Canada
    Thanks for the help! Really appreciated!
  1. Changing a wheel stud?
    By Z28 in forum General Tech Discussion
    Last Post: 04-13-2011, 03:30 PM
  2. Easy way to install a new wheel stud?
    By Deezul_AwT in forum Tires & Wheels
    Last Post: 08-12-2010, 05:44 PM
  3. How to fix broken wheel stud?
    By ryangtp89 in forum Brakes/Suspension/Chassis
    Last Post: 10-08-2008, 10:59 PM
  4. &#@$ing Wheel Stud
    By Abrasive in forum The Rant Forum
    Last Post: 04-01-2008, 05:44 PM
  5. rear wheel stud-how to get it out and new installed?
    By fst in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2008, 03:47 PM
