Thread: Couple Tire Questions
Results 1 to 7 of 7
  1. #1 Couple Tire Questions
    Apr 2014
    Minneapolis
    Whudup guys. So I tend to street race every weekend and I'm noticing my tires squeal a lot. I heard deflating the front tires to 32 psi for more grip, and 35 psi for the rear tires works. First question: Is this true? It makes a lot a sense from my perspective, but then again, I may be wrong. Second question: What would be the best tires with good grip for under $100? Also what would be the best winter tires for the best price. I know that was random, but I live in Minnesota where it snows 7 months out of the year. Thanks in advance
    Brent's Boat with Boost - 00' GTP | 3" Downpipe w/cat | U-bend Delete | Polyurethane Motor Mounts | K&N Cold Air Intake |180* Thermostat | Tuned PCM | Powerlog Front Exhaust Manifold | 3.5" Supercharger Pulley | Autolite 104 Spark Plugs | TransGo Shift Kit
  2. #2 Re: Couple Tire Questions
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Whats your current tires also, I think 30psi is what ur supposed to be running anyway, at least thats what it says on the door. You're probably going to spend over 100 a tire for anything with better grip. Also running stickier tires puts more strain on the trans, please tell me this "street racing" is on a closed track/strip....
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Couple Tire Questions
    $100 a tire can get you a decent set of snows. It won't likely get you anything that grips better in the summer. You may want to consider working on your launches. You control the squeal
  4. #4 Re: Couple Tire Questions
    Apr 2014
    Minneapolis
    Thanks for the information. I currently have 16" rims on right now. Sorry I didn't clarify, but you are correct about the "street racing" is on a track that's near by where I live.
  5. #5 Re: Couple Tire Questions
    Apr 2012
    Goderich, Ontario
    Quote Originally Posted by M7x350z View Post
    Street racing on a track? Ummm... Isn't that just racing? Also, I run all 4 tires 30-32psi.
    -Paul Walker
  6. #6 Re: Couple Tire Questions
    SWPA
    For better grip you want to drop the front tires to about 25 psi or even a little lower. The reasoning is that letting the air out will let the tire squat a little and create more surface area and also help prevent wheel spin. It's the same basic theory why rock crawlers drop their tire pressure.
  7. #7 Re: Couple Tire Questions
    Didn't know there was a "track" near minneapolis, where is it?
  1. Couple AC Questions
    By SomeDudeAtHome in forum General Tech Discussion
    Last Post: 08-24-2013, 09:52 AM
  2. New here, couple questions.
    By osiris94ej in forum Introductions/Noob Questions
    Last Post: 11-16-2012, 10:07 AM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. I Have a couple questions.
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2008, 08:07 PM
  5. couple questions on my gt
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-04-2008, 08:58 PM
