Thread: 05 gp offset?
Results 1 to 15 of 15
  1. #1 05 gp offset?
    Jan 2014
    United States
    im doing some future aftermarket wheel shopping for my 05 gxp and im looking at a set of 19 inch mach m5's and the offset is +45 and im trying to figure out what a good offset range is for this car so the rims dont rub up front or just stick out to far past the edge of the wheel well in general and look goofy. any help on this?
    THE RIDES OF 2014​ 98' dodge ram 1500 sport/raminator-DD
    97' ford f-150 xlt-mud toy
    97' monte carlo z-34-project never to be done
    05' grand prix gxp-weekend warrior
  2. #2 Re: 05 gp offset?
    Dec 2012
    troll land
    I think stock is 52mm, itll say on the back of your stock wheels
  3. #3 Re: 05 gp offset?
    Jan 2014
    United States
    my stock wheels are on the car which is out burried in the snow and in which is an even worse matter i have a broken leg and couldnt go check even if i wanted lol
  4. #4 Re: 05 gp offset?
    Dec 2012
    troll land
    Sorry to hear that
    But i think it was either 52mm or 56 mm , been a wbile since i had a gp wheel
  5. #5 Re: 05 gp offset?
    18in GXP rims might be a slightly lower offset than the 16in or 17in rims that are somewhere around 52.
    Stay above a +36ish and you won't have an issue with rubbing. So +40-45 is a good spot to make sure it won't be an issue.
  6. #6 Re: 05 gp offset?
    Dec 2012
    troll land
    ^thanks
  7. #7 Re: 05 gp offset?
    SE Level Member FASGP's Avatar
    Toronto ON
    I believe stock is 52. I run 40 offset 18's and find them perfect to need only slight inner fender lip rolling, and the stance looks great. I have run 38 offsets, and the stance is nice as well. Most mustang rims are 38, so if you see a photo of a GP with bullitts, thats the look.
    These are 40 offset 18" with 245 rubber
    These are 45 offset 18" with 235 rubber
    Vtec...All the lag and none the turbo...it's like waiting for bad sex
  8. #8 Re: 05 gp offset?
    Jan 2014
    United States
    thanx for all the info guys this helps me out alot, i figured this would be the first place to start with the right info.
  9. #9 Re: 05 gp offset?
    Jan 2014
    United States
    Quote Originally Posted by FASGP View Post
    the 18 40mm offset looks like right where i wanna be
    your car looks good my man
  10. #10 Re: 05 gp offset?
    Toronto ON
    Thanks. I love the 40's as well. I since converted those 45's to winters with plasti-dipped black spokes...
  11. #11 Re: 05 gp offset?
    Jan 2014
    United States
    do the 45s stick out allittle farther?
  12. #12 Re: 05 gp offset?
    you've got to realize that the difference of 10mm in offset isn't going to matter much. the wheel width plays a lot more into that.
    until you get into the +30mm or less offsets, they all fit pretty fine.
  13. #13 Re: 05 gp offset?
    Toronto ON
    Quote Originally Posted by LSFoFaSho View Post
    No, the 45 is further in. I did not have to roll anything to run 45 offset with 235 rubber. I did have to roll a little for the 40's with 245 however, but that is lowered with 97-03 SSC springs. Stock ride height may be ok.
  14. #14 Re: 05 gp offset?
    lowered 2" 29.5 offset 17" I had to roll my rear fenders
  15. #15 Re: 05 gp offset?
    Jan 2014
    United States
    thanx for everyones input u guys, every little bit helps
  1. Offset?!?!?
    By Speedy1973 in forum Off Topic Discussion
    Last Post: 08-27-2012, 08:18 PM
  2. rim offset
    By Scottydoggs in forum General Tech Discussion
    Last Post: 02-25-2012, 12:40 AM
  3. Help on offset
    By rambo33 in forum Tires & Wheels
    Last Post: 06-14-2010, 11:19 AM
  4. 2005 GXP Offset (Help)
    By Alwayztru in forum Tires & Wheels
    Last Post: 01-29-2010, 06:50 PM
  5. Offset
    By gpgt04 in forum Tires & Wheels
    Last Post: 07-18-2009, 12:30 PM
