Quick question guys, will 16 inch steel wheels fit on 2005 grand prix gxp?
I need some winter rims and tires and not sure if 16 inch will clear the brakes.
Thanks
Thanks
Do you know how much offset?
I should say more so that you need to make sure the spokes dont hit the calipers, but offset of the rim will still play a role in weather they fit or not. I think stock is near the +40-50 range, so stick with that range offset of the rim.
On the hunt for winter rubber on the stock gxp rims.
Hard to find in the factory sizes. Would 245/50/18 all around work?
Even tho front is 18x8 and rear rim is 18x7?
Thanks
play with this link, you can figure out whats closest to the stock size.
http://www.tacomaworld.com/forum/tir...0r16-225-45r17
