Thread: GTP Warning Lights Causing Problems
Results 1 to 3 of 3
  1. #1 GTP Warning Lights Causing Problems
    Sep 2013
    Iowa
    I bought a 2004 Grand Prix GTP with the Competition Group Package about a month ago. From day one i was told that i had a bad wheel bearing causing my ABS light, Parking Break Light, and Traction Controll Light to come on constantly. i also am having difficulties with my car changing gears, it feels as if my transmition was slipping (im begining to wonder if it is from all of the warning lights that are on) I am starting to get irritated because i have replaced all 4 bearings and put new break pads on the back tires. I also have about every light that could flash up on the Drivers Information Center on, and a whining noise when i turn my wheel. also, the car has now strted jerking while driving at a high speed causing the check engine light to come on. Please Help, Im not sure what else to do.
    Thanks,
    SILVER2004GTP
  2. #2 Re: GTP Warning Lights Causing Problems
    We need the check engine code to help you more. Its also possible the transmission has thrown a code aswell.
    As for the ABS, perhaps there is still a problem with a wire harness to a hub or the ABS module needs to be rebuilt. You will have to get the car scanned to see what ABS code its throwing. That code should tell you what wheel(s) its coming from or if its a internal fault with the ABS module.
  3. #3 Re: GTP Warning Lights Causing Problems
    GTX Level Member blackflag's Avatar
    Virginia
    so you replaced all hubs without checking the code?
  1. huge exhaust leak resulting in loss of back pressure causing tranny problems?
    By McCoyH in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2012, 09:35 AM
  2. HID lights causing static!
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 02-08-2012, 11:35 PM
  3. warning lights on no problems with engine
    By neorules in forum General Tech Discussion
    Last Post: 05-28-2011, 09:17 AM
  4. Need help with warning lights!!
    By 91z in forum General Tech Discussion
    Last Post: 03-10-2011, 09:54 PM
  5. HELP! Warning lights aplenty
    By cmw1876 in forum General Tech Discussion
    Last Post: 09-09-2010, 08:16 AM
