Thread: 18x7.5 24mm offset rub?
Results 1 to 7 of 7
  1. #1 18x7.5 24mm offset rub?
    GT Level Member Xanthous's Avatar
    Apr 2011
    St. Louis
    How much trouble w/ rubbing will I run into?
  2. #2 Re: 18x7.5 24mm offset rub?
    May 2008
    Winnipeg, MB
    my 8.5" wide wheels rubbed a bit, yours are 1" less, you will be fine
    2007 Pontiac Grand Prix
  3. #3 Re: 18x7.5 24mm offset rub?
    That's a good amount of poke
    04 Comp G.
  4. #4 Re: 18x7.5 24mm offset rub?
    Apr 2011
    St. Louis
    You have 24mm offset tod? Do you have any pics?
  5. #5 Re: 18x7.5 24mm offset rub?
    24mm offset isn't that big of a deal on a 7.5" wide wheel. it should fit fine.
  6. #6 Re: 18x7.5 24mm offset rub?
    Apr 2011
    St. Louis
    Thanks for writing bio. These wheels that I'm looking at have tires on them. Is there a certain size I need to stay under?
  7. #7 Re: 18x7.5 24mm offset rub?
    245/45/R18 is what most of us would run on an 18.
    stick around that size, just move around the widths and keep the sidewall the same height.
  1. Best tire size for 18x7.5 wheels???
    By rodguezsciii in forum Tires & Wheels
    Last Post: 03-30-2013, 10:26 AM
  2. 18x7.5 24mm offset fit?
    By Xanthous in forum Tires & Wheels
    Last Post: 12-06-2011, 09:50 AM
  3. Good idea to swap 18X7 for 18X8?
    By VDV18 in forum 5.3L V8 (LS4)
    Last Post: 01-19-2010, 05:38 PM
