Thread: Pre Gen questions
Results 1 to 5 of 5
  1. #1 Pre Gen questions
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    Im looking to pick up a set of PreGens, the 5 spoke ones. I have pretty much lined up the sale. I have questions though.
    1. I have seen that people run them when lowered but with a wide tire, like a 255 is there any rubbing when you have weight in the car, like 4 full size males.
    2. Will they clear Fbody front brakes and GXP rear brakes
    3 if I strip the paint of them is it aluminum under there? and if so can it be polished and clear coated?
    Thanks!
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
  2. #2 Re: Pre Gen questions
    antioch ill
    they are a real pain to strip. i had mine sandblasted and it took about a hour per wheel. they shouldnt rub unless you have some thick ass trailing arms. for the brakes i cant help you there
  3. #3 Re: Pre Gen questions
    255 would be too wide and would rub if you didnt do something with the fenders.
    The stock 225/60 tire shouldnt rub at all even when lowered on says SSC/vogtlands/eibachs springs.
    They should still clear the brakes because its still a 16in rim.
  4. #4 Re: Pre Gen questions
    May 2011
    Tampa FL near USF
    Quote Originally Posted by Matt Palm View Post
    I have the GMPP trailing arms, so i should be good. Did u sand blast them polish or paint them?
    Thanks for your help
  5. #5 Re: Pre Gen questions
    antioch ill
    they are getting powder coated. dropped em off friday and getting em back sometime this week.
  1. UIM questions
    By nos4blood70 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2012, 05:36 PM
  2. hid kit questions
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2012, 01:08 PM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  5. Few Questions
    By shape275 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 09:10 PM
