Thread: ABS light on after putting on 17 inch wheels
Results 1 to 7 of 7
  1. #1 ABS light on after putting on 17 inch wheels
    SE Level Member ImColeTrickle's Avatar
    Apr 2011
    Athens, Alabama
    After a few miles of driving my abs light comes on and I no longer have anti-lock brakes. Any ideas on how to fix it?
    Crashed 1997 GP GT Mods: Ebay Intake, SSAC Headers, 2.5" ZZP Catback, Poly Uppers, Polished Aluminum DB's, ZZP 1.0 PCM, 6000k HID's
    New Car: Black 2002 GT 4dr Stock
  2. #2 Re: ABS light on after putting on 17 inch wheels
    Did you knock a wheel speed sensor loose? Same size wheels all the way around?
  3. #3 Re: ABS light on after putting on 17 inch wheels
    Apr 2011
    Athens, Alabama
    I don't think I did. And yeah everything is the same size
  4. #4 Re: ABS light on after putting on 17 inch wheels
    GTP Level Member
    springfield IL
    Check your sensors again... This happened when I put 22s on mine years ago. Shop knocked off a sensor.. :-/
  5. #5 Re: ABS light on after putting on 17 inch wheels
    Apr 2011
    Athens, Alabama
    I'm starting to think its not the wheels. I'm getting this horrible grinding noise and this fluctuation in the brake pedal. So I'm thinking that either the ABS Pump is going out or one of my sensors on my wheels is broken
  6. #6 Re: ABS light on after putting on 17 inch wheels
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    If the sensors are all connected properly...
    Could be that there's corrosion in 1 of the harnesses from a broken wire (its common). Unplug them at the bearing and car side and check the pins. If there's corrosion on 1 or both pins, replace the harness.
  7. #7 Re: ABS light on after putting on 17 inch wheels
    GT Level Member JaredR215's Avatar
    Jul 2011
    Cheyenne
    I had some pretty bad grinding a few weeks back. pulled off my rotor to find that one of my HUB bolts had somehow come loose and was letting the wheel tilt just enough to grind when making corners and screwing with my brake pressure.
    K&N Cold Air, ZZP Wires, ZZP 3" with hi-flo, Catback, ZZP 1.0 PCM., 180*, AL605's, 3.5 MPSStill fighting KR
  1. 9 inch wheels
    By Angelo1912 in forum Tires & Wheels
    Last Post: 08-27-2012, 10:17 AM
  2. 17 inch wheels
    Last Post: 06-21-2012, 12:55 PM
  3. Will 16x7 inch wheels fit on my GTP?
    By cmal37 in forum Tires & Wheels
    Last Post: 09-22-2011, 11:24 PM
  4. 17 inch Pontiac G6 wheels
    By ls6velless454 in forum Tires & Wheels
    Last Post: 02-16-2010, 02:18 AM
