Thread: Best tire size for 18x7.5 wheels???
Results 1 to 20 of 26
  1. #1 Best tire size for 18x7.5 wheels???
    GTP Level Member rodguezsciii's Avatar
    Sep 2012
    Sorry if this has been beat to death....but considering a drop from a set of SSCs, would 235/50 or 225/50 be optimal for a 7.5 wide wheel?
    Wheels are 18x7.5, 42
    Most tire calculators seem to suggest 235/50....anybody with.a 7.5 wide wheel or anybody obviously with more experience with tire specs care to chime in, would appreciate it...
    I am also performance over visual when it comes to tires
  2. #2 Re: Best tire size for 18x7.5 wheels???
  3. #3 Re: Best tire size for 18x7.5 wheels???
    I live here. TLSheff's Avatar
    ^ This. The 245/45 is also a very common tire so you run a better chance of getting a bigger option for brands and a cheaper cost.
  4. #4 Re: Best tire size for 18x7.5 wheels???
    Sep 2012
    I thought 245 on a 7.5 wide wheel was max/overkill....?
  5. #5 Re: Best tire size for 18x7.5 wheels???
    It might be a little fat on the rim, but it will go on without any problem. Unless you want that stretched look, a 245 on a 7.5"/8" wide wheel will fit perfect.
    Mine are 18x8 +35, with 245/45/18 Goodyear Eagle RSAs. Stock height. Fit and ride perfect.
  6. #6 Re: Best tire size for 18x7.5 wheels???
    SWPA
    245 works on anything from 7.5"-9", though its starting to stretch a little on 9"
  7. #7 Re: Best tire size for 18x7.5 wheels???
    Sep 2012
    So all things considered the possible 2 inch drop wont cause rubbing? ....I dont plan on rolling fenders.....thx 4 all input btw
  8. #8 Re: Best tire size for 18x7.5 wheels???
  9. #9 Re: Best tire size for 18x7.5 wheels???
    Dec 2012
    Hawai'i
    245/45/18 would be fine, although I wouldn't go any skinnier than a 7.5 on it. I run 235/45/18 on my 7.5" wide wheels. A 235/45/18 is also rated for a minimum width of 7.5 and I think it looks good so a 245/45/18 should as well.
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  10. #10 Re: Best tire size for 18x7.5 wheels???
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    245/45s might rub with a 2" drop.
    I would go 245/40s
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  11. #11 Re: Best tire size for 18x7.5 wheels???
    Dec 2012
    Hawai'i
    Quote Originally Posted by Ridin ON Chrome View Post
    I would go 245/40s
    I highly doubt they will with his offset
    I've got an offset of 25 and am basically lowered that much.
  12. #12 Re: Best tire size for 18x7.5 wheels???
    Houston/Baton Rouge
    Quote Originally Posted by barnettimpala View Post
    My wheels are the same offset/size and I cant fit 245/45s in the rear. That's why I run 245/40s all around.
    I tired putting my 245/45s on from my Buick and they rub . At least for me.
  13. #13 Re: Best tire size for 18x7.5 wheels???
    Feb 2013
    Detroit, MI
    I have 245/40/19s on a 19x8 +40 offset wheel n no issues. Just lowered it n no problems. 245/45/18 n you're good to go like the others said.
  14. #14 Re: Best tire size for 18x7.5 wheels???
    Houston/Baton Rouge
    Quote Originally Posted by GrandPrix06GT View Post
    You have a 04+. They have more fender room
  15. #15 Re: Best tire size for 18x7.5 wheels???
    Feb 2013
    Detroit, MI
    Op does too! I was talking with him yesterday.
  16. #16 Re: Best tire size for 18x7.5 wheels???
    Houston/Baton Rouge
    Well, he should have stated that. It does make a difference.
  17. #17 Re: Best tire size for 18x7.5 wheels???
    Feb 2013
    Detroit, MI
    Lol yeah I guess so, I thought one had more flare but forgot which year had it.
  18. #18 Re: Best tire size for 18x7.5 wheels???
    Dec 2012
    Hawai'i
    With a 7.5" wide wheel and that offset I see the tire rubbing the fender liner from being so low way before the fender. Hell I even have 5/16" spacers on the rear so that's like a 7.5" wide wheel with a +17 offset
  19. #19 Re: Best tire size for 18x7.5 wheels???
    Houston/Baton Rouge
    At times my rear wheels will sit almost flush with the rear fender. I do have a system in the trunk. It barley hit fenders with the 245s. Now the 18s on the buick are 18x8 with a 38mm offset. +42 is not going to make much of a difference.
    There's no way it would rub the fender liner, it would rub the strut perch before it would rub any liner.
  20. #20 Re: Best tire size for 18x7.5 wheels???
    Dec 2012
    Hawai'i
    Mine sits that low too lol. I only rub fender if I take a corner really hard and it barely does then. But like I said I'm at an equivalent of a +17 offset. Which is WAY more poking out than a +42. I just don't see how you rub.
    And a 38 to 42 offset is enough of a difference to matter when your talking about rubbing or not.
    And no the fender liner it above the tire too and goes all the way over to the fender.... So if you were low enough you would rub that.
    To the op, just do it lol
  1. What tire size do you run on 18" wheels?
    By Jochen in forum Tires & Wheels
    Last Post: 03-13-2015, 11:53 PM
  2. Tire Size
    By jamster00 in forum Tires & Wheels
    Last Post: 12-13-2011, 01:29 AM
  3. Tire Size??
    By 2005GrandPrix in forum Tires & Wheels
    Last Post: 04-30-2011, 12:02 AM
  4. Tire size 235/55?
    By RedLedbetter in forum Tires & Wheels
    Last Post: 05-09-2009, 02:14 PM
