Thread: Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
Results 1 to 20 of 30
  1. #1 Will 255/45-18 wheels rub on dna drop springs? Wheel experts need advice!
    GTP Level Member buickman104's Avatar
    NYC
    I am tired of bent rims and want a tire with more side wall i plan on buying 255/45 series tires. My rear fenders are rolled. Will i run into any rubbing issues?
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: Will 255/45-18 wheels rub on dna drop springs?
  3. #3 Re: Will 255/45-18 wheels rub on dna drop springs?
    Aug 2012
    Michigan
    255/45 is going to be a hair wider. But, as far as preventing bent rims, its only 2/10 of an inch taller than a 245/45, so it really is not much more cushion.
  4. #4 Re: Will 255/45-18 wheels rub on dna drop springs?
    ^ he's right.
    run less air pressure in your tires. save wheels at the expense of a little less MPG.
  5. #5 Re: Will 255/45-18 wheels rub on dna drop springs?
    NYC
    Yup. It is also a comfort issue. According to the miata tire calculator I would be going from a 3.9in sidewall to a 4.5in sidewall.
    My current tire size is 245/40-18 reason I got that size was because the tires were almost new and got them for a steal. But tired of the rough ride and want more meat on my wheels.
    So the overall consensus is that i should be fine running 255/45-18 tire size on my 1 inch drop DNA springs?
  6. #6 Re: Will 255/45-18 wheels rub on dna drop springs?
    Jan 2009
    Tallahassee, FL
    Yea, what's the offset of your wheels though? That might come into play if its low enough. Although you're already running 245s I'd say you'll be fine.
    245/45 puts you at the stock height anyways.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  7. #7 Re: Will 255/45-18 wheels rub on dna drop springs?
    NYC
    konig Backbone
    Diameter 18.0”
    Width 8.0”
    Bolt Pattern 5-114.3mm
    Offset 45
  8. #8 Re: Will 255/45-18 wheels rub on dna drop springs?
  9. #9 Re: Will 255/45-18 wheels rub on dna drop springs?
    Banned
    Jan 2013
    the bandwagon follower aka noobiee
    post pics
  10. #10 Re: Will 255/45-18 wheels rub on dna drop springs?
    Dec 2012
    Hawai'i
    With that offset, you should be just fine
  11. #11 Re: Will 255/45-18 wheels rub on dna drop springs?
    Dec 2008
    Lawndale, CA
    Will be fine. But I doubt the drop will be that much with those springs with the pics I have seen.
  12. #12 Re: Will 255/45-18 wheels rub on dna drop springs?
    Nov 2011
    NY
    I put 255/45/18 on my new Enkei's and New KYB quick struts ... And have rub! It's not the fender, the tire actually hits the spring perch on the bottom of the strut. Only when I have weight in the rear. I think I have pics, I will post if I do.
  13. #13 Re: Will 255/45-18 wheels rub on dna drop springs?
    Dec 2012
    Hawai'i
    Must be a high offset.
    Put on some thin spacers
    2002 Impala- SSC, AGX, 18" charger R/t rims w/8mm spacers, Magnaflow cat, U-bend delete, flowmaster 80 series crossflow, z28 tips, HAI, debadged, 35% tint, smoked headlights, full sound system
  14. #14 Re: Will 255/45-18 wheels rub on dna drop springs?
    that doesnt move so if it doesnt rub just sitting there then it should never rub.
  15. #15 Re: Will 255/45-18 wheels rub on dna drop springs?
    Dec 2012
    Hawai'i
    I'm assuming it sits so close that with a loaded car the tire bulges towards the perch some and rubs. Tire shouldn't bulge a considerable amount I wouldn't think tho so maybe your not running enough pressure?
  16. #16 Re: Will 255/45-18 wheels rub on dna drop springs?
    Banned
    Jan 2013
    lol he like in queen or ny right lol there pothole everywhere these ny street suxxx
  17. #17 Re: Will 255/45-18 wheels rub on dna drop springs?
    Nov 2011
    NY
    My thinking is to eliminate it by throwing in coilovers in the rear for now, lol. I know the lower strut doesn't move but on right hand turns with weight oin the rear it rubs. There's no markings anywhere else (wheelwell) so... Obviously 245's would've been the right move. Drunkie suggested I sell them, might still as they got barely 5k on em... Great rubber too. I just don't want to go through the trouble of mounting new tires... Lazy I know. The spacers are an idea I haven't considered, interesting and a possible cure!
  18. #18 Re: Will 255/45-18 wheels rub on dna drop springs?
    Jan 2009
    Tallahassee, FL
    Coilovers would be worse if you're already rubbing. The spring goes over the strut so there's now less clearance.
    77 Morris Garage B
  19. #19 Re: Will 255/45-18 wheels rub on dna drop springs?
    top 5 dead or alive OmegaRed's Avatar
    Feb 2010
    Medford, Oregon, United States
    thats what i ran with a 42mm offset and didnt rub at all
  20. #20 Re: Will 255/45-18 wheels rub on dna drop springs?
    SE Level Member oldsman105's Avatar
    Queens, New York
    Quote Originally Posted by buickman104 View Post
    BAHHAHAHAHAHAHHAHAHA!!!! You think going to a 45 height tire is going to safe you from NYC pot holes ? HAHAHHHHAAHHA!
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  1. The day I get my drop springs...
    By ZR1Vette09 in forum Off Topic Discussion
    Last Post: 05-10-2010, 10:40 PM
