Thread: Bumper to bumper warranty affected by adding Rims / Lowering ??
Results 1 to 19 of 19
  1. #1 Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    Hey i just bought a 2007 GP and wanted to put 18'' Saleen style rims with 255/45/18 tires. also maybe lower it an inch or so.
    Anyone know if this will affect an active bumper to bumper warranty if i make these changes. i know i should pry call my warranty provider but just thought i would ask. thanks
  2. #2 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    call and ask.
    and those are gonna rub and stick out goofy.
  3. #3 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    And the warranty company is going to say .. Void
  4. #4 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    is it the suspension tweak that will most likely void it?
  5. #5 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    call and ask.
  6. #6 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    You are changing the geometry of the suspension, so that'll be voided. You are putting a much larger stress on the drivetrain so it'll be voided.
    Add the two together and likely they'll start laughing at you.
  7. #7 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Quote Originally Posted by ctemp1 View Post
    yeah, the offset is too low and the wheels are too wide for most people. it's gonna look like a mini truck.
  8. #8 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    i dnt know if you have seen that white car around on this site before, do you have any idea how he pulls it off so good with these wheels and 30mm offset?
  9. #9 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    if you get a straight on picture from front or back youll see that the wheels/tires stick out past the fenders. that look terrible to me.
  10. #10 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    That is Milestone's GP. He rubs as far as I know from the last time I talked to him, so fenders were rolled
    He is on SSC springs.
    How much of warranty do you have left? It is a 2007, I can't imagine there being that much of a warranty on it.
  11. #11 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    i just bought it with 35k. so i added extra warranty, bumper-bumper for 4 years, or 35k more miles
  12. #12 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    what set up are you rollin Drunkie? are those saleens as well in your sig?
  13. #13 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    he's running skinnier tires with less than optimal alignment specs. he's also running pretty low on a set of coilovers.
  14. #14 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    You could always swap the springs and wheels out if you need warranty work done. Other then that it'll void your warranty if you bring if to the dealer like that.
    04 Comp G.
  15. #15 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    thats what im thinking. but i also want that aggresive look once lowered. AHH ill call the warranty companty tonight..
  16. #16 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    ~3.5" drop on coilovers with American Muscle Mustang GT500 Replica 19x8.5's 30mm offset with 235/45/19s, fenders are rolled flat all around and my splash shields are all cut up.
  17. #17 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Probably one of those things you might of wanted to consider prior to buying a warranty. Pretty much you get one if you plan on leaving the car stockish besides aesthetics on that outside and maybe stereo. I'm sure they would tell you for certain once you give them a call but there's a bunch of hidden things that can void it just a FYI.
    04 Comp G.
  18. #18 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    They are really picky with some of that stuff, they tried to void my warranty on my car because I had by Bluetooth OBDII adapter plugged in.
  19. #19 Re: Bumper to bumper warranty affected by adding Rims / Lowering ??
    Feb 2013
    Omaha
    thanks for all the input on this guys. and thanks for your set up drunkie! $H*T is very pretty
  1. bumper help!!!
    By uspolack in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-19-2012, 06:52 PM
  2. 05 GP OEM Bumper
    By Poseidon215 in forum Visual/Body Modifications
    Last Post: 09-05-2010, 05:38 PM
  3. SE Rear Bumper/GT front bumper cover...
    By Mad Monkey in forum Visual/Body Modifications
    Last Post: 05-01-2010, 07:14 PM
  4. GTP bumper on a SE
    By irupp33 in forum Visual/Body Modifications
    Last Post: 01-07-2010, 08:35 PM
