Thread: are wheel spacer good or bad?
Results 1 to 20 of 35
  1. #1 are wheel spacer good or bad?
    SE Level Member 03limitedgtp's Avatar
    Sep 2011
    ohio!
    I have a 2003 limited gtp and I don't wanna take of the limited edition wheels but looking for a wider stance would it be bad to get 1 1/2 or 2in spacers?
    I live here. DirtDog's Avatar
    Jun 2012
    Don't think I've ever seen anyone with a go do that big of a spacer?
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: are wheel spacer good or bad?
    Donating User Odi's Avatar
    Chicago South Suburbs
    - Hub-centric spacers is preferred over the generic spacers as they are more stable thus less vibration issues.
    - Use of spacers can lead to "premature" wheel bearing wear, but the term premature is relative. So you will have to decide if the risk is greater than the benefit. Although with the ****ty hubs we have on w-bodies, Id stay away.
    - Use of spacers can lead to "premature" suspension wear also, if the offset is large enough. If the difference is that great, you may want to consider having an alignment done on the car.
    - Wheels falling off is another possibility with spacers, but it is most likely to happen because of user did not get the correct bolts or installation error. However, since it is an add-on parts, the possibility of spacers cracking also exists. It is rare, especially with quality spacers, but it is not impossible.
    IMO, wheels with build in desired offset > hub-centric spacers > ebay spacers. That said, having run the wheels you have, Id just get rid of them and get something nicer. Proper quality spacers will cost you some big bucks. (~400 bucks per 4 proper hubcentric spacers bigger than 15mm)
  4. #4 Re: are wheel spacer good or bad?
    Pennsylvania
    It's really not worth worrying about it every time you drive, is my wheel gunna come flyin off at 60mph, did that last pot hole finally do it? Is this gunna kill my wheel bearings? Is this murdering my tires from the suspension being out of whack?
    Just go to tire rack and get some nice wheels with a better offset. Mustang wheels work nice.
    Sport Edition Kv5 18x8
  5. #5 Re: are wheel spacer good or bad?
    there's literally nothing wrong with spacers so long as everything is installed correctly.
  6. #6 Re: are wheel spacer good or bad?
    Dec 2012
    Hawai'i
    Quote Originally Posted by FriboRage View Post
    LOL b/c wrong bolt patterns are better than spacers. Idk would you rather risk breaking wheel studs? Argument goes both ways. I have 8mm spacers with no problems but that's considerably smaller than you are wanting
    Quote Originally Posted by barnettimpala View Post
    Em incorrect there broham. Plenty of guys run the mustang 5x114.3 and have yet to break a wheel stud. Hell most of us run 5x114.3 because there's a bigger selection of wheels. For the past 4 years I've ran 114.3 with 0 broken studs. The different between 115 and 114.3 is very minor. You could always run centric hubs if you feel the need.
    04 Comp G.
    A minor spacer is fine but I would go any bigger then 10mm. Personally arp wheel studs are cheap enough to change out to if there's any concern.
    04 Comp G.
  9. #9 Re: are wheel spacer good or bad?
    SWPA
    People are not going to break wheel studs because of running a 5x114.3 vs a 5x115. Chances are, those who are breaking wheel studs, would have broken them running a 5x115 wheel anyway.
    ^ and over tightening there lugs.
    04 Comp G.
  11. #11 Re: are wheel spacer good or bad?
    SWPA
    Exactly. Everyone impacts lug nuts on. You aren't supposed to use the impact to put lug nuts on. You are only supposed to use it to remove them.
  12. #12 Re: are wheel spacer good or bad?
    Exactly. Now tell those so called mechanics who rather be lazy and impact them on
    04 Comp G.
  13. #13 Re: are wheel spacer good or bad?
    Dec 2012
    Hawai'i
    I'm not saying he would have a problem, but it's about as common as having problems with small spacers, as we both mentioned, wouldn't be a problem.
    I don't think you should waste on spacers with stock wheels
  14. #14 Re: are wheel spacer good or bad?
    0.7mm (1/36th of an inch) is within manufacturing error. considering mustang wheels fit and have practically the same (70.5 vs 70.3 on w-bodies) hub bore as w-bodies, theres nothing to worry about. if you break studs with a 5x114.3 wheel, you either overtighten lugs or have damaged (or worn) studs.
    edit: apparently boostengtp managed to break his studs with stock torque stars lol.
    Ehh no everyone has the money to buy aftermarket rims..spacers are much more affordable.
    04 Comp G.
  16. #16 Re: are wheel spacer good or bad?
    Dec 2012
    Hawai'i
    Small cheap spacers on stock wheels won't be that noticeable so a waste of money. Big spacers that will be noticeable cost a lot more.
    Not noticeable to you but to the owner you never know. Don't knock it just because you think it's a waste of money.
    04 Comp G.
  18. #18 Re: are wheel spacer good or bad?
    Dec 2012
    Hawai'i
    I said originally "I DON'T THINK". That is my opinion on it, that it's a waste of money. Also my opinion is that it really isn't that noticeable unless the tires are relatively close to the fender, ie low and flush
  19. #19 Re: are wheel spacer good or bad?
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    ive used 1 1/4" wheel adapters just for off set, Welcome to Mopac Auto Supply - Performance World Wheel Accessories, they worked great, no problems. keep in mind i used them on lighter car, not a gp.
    however i paid 80$ a pair (160$), i shoulda waited two more weeks, 17/18" wheels are fairly cheap now
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  20. #20 Re: are wheel spacer good or bad?
  1. rear wheel drive '02 gp, good idea?
    By deuce in forum General Grand Prix Discussion
    Last Post: 06-17-2013, 11:43 PM
  2. Thickest wheel spacer
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 06-13-2012, 12:42 AM
  3. Wheel spacer help
    By cbolts gtp in forum Tires & Wheels
    Last Post: 05-07-2012, 08:54 AM
  4. 2006 GXP Wheel Spacer
    By jsal924 in forum Introductions/Noob Questions
    Last Post: 06-12-2011, 10:20 PM
  5. ZZP Wheel Bearing - Any good?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2009, 03:31 PM
